Rearranging Series to Equal SQRT2: How to Solve
  • Thread starter andrey21
  • Tags
    Series
In summary: \sum_{n=1}^{+\infty}{\frac{1}{n^2}}=\sum_{n=1}^{+\infty}{\frac{1}{(2n)^2}}+\sum_{n=1}^{+\infty}{\frac{1}{(2n+1)^2}}so\sum_{n=1}^{+\infty}{\frac{1}{n^2}}=\sum_{n=1}^{+\infty}{\frac{1}{6}}+\sum_{n=1}^{+\infty}{\frac{1}{9}}which
  • #71
fantastic I just have to use the binomial therom now it says to prove this. what part would i apply this to?
  • #72
Think I have solved it:
Using (1+x)^r where r is not a whole number. I obtain:
1+3/2.(n) - 1/8 - 1/16 ...
so as the expansion continues the values get closer to zero leaving 1 + 3/2(n)
  • #73
I realize I may have ae a mistake. Am i on the rite track?
  • #74
Use the binomial theorem to prove what??
  • #75
the limit I think.
  • #76
No, I'm just confused. What exactly are you trying to prove now?
  • #77
My original question stated. Using simple algebra find the limit of this sequence as n tends to infinity. Then confirm this using the binomial therom.
  • #78
I have no idea what they mean with "confirm with the binomial theorem"...
Do they mean this:
[tex](x-y)^r=\sum_{k=0}^{+\infty}{\binom{r}{k}x^{r-k}y^k}[/tex]
if so, you just need to substitute x=n2, y=3n and r=1/2...
  • #79
Possibly, if that is the case I just sub in values for x y and r. Then what?
  • #80
Calculate [tex](n^2-n)^{1/2}-n[/tex] with the binomial theorem. What does that give you?
  • #81
Sorry I am nt to sure how to do that when r = 1/2
  • #82
Ok well I am going to come back to that. The bext question I am asked is to describe the sequence that SQRT(n^2 +3n) -n generates:
Substituting in values for n I obtain:
0,1,((SQRT10)-2),((SQRT18)-3), ((SQRT28) -4),...
From this am i correct in saying it is positive and monotonic, And converges to 3/2 as already discovered. Are there any upper lower bounds?
  • #83
You'll have to prove that it is positive and monotonic...
  • #84
Ok well monotonic is where the next value is greater than or equal to the previous one correct?? So can't I just set two values next to each other:
1<((SQRT10) -2)
  • #85
Yes, but this only proves it for n=1 and n=2. You'll need to show it for every n. You'll need to show that for every n
[tex]\sqrt{n^2+3n}-n\leq \sqrt{(n+1)^2+3(n+1)}-(n+1)[/tex]
  • #86
Ah ok so from what u have written above. As the sequence is increasing we can say:
an + (an+1) is always positive.
so an + (an+1) = SQRT(n^2 +3n)-n + SQRT((n+1)^2 +3(n+1)) -(n+1)
  • #87
No, you need to prove that...
  • #88
Scratch that above should it be an+1 - an is always positive??
so I will have:
an+1 - an = + SQRT((n+1)^2 +3(n+1)) -(n+1) - SQRT(n^2 +3n)-n
  • #89
Yes.
(note: the forum rules explicitely forbid that you edit posts that allready have been answered to. So please do not do this)
  • #90
Rite so is that just the answer then??
  • #91
Yes, I suppose so...
  • #92
Great Thank u micromass now I just need to work out the binomia therom part of the question.
  • #93
Hey micromass could u possibly help me on a thread I've created regarding a partial differential equation. I am having a little trouble. Thanks in advance.
