Homework Help: Recursion Tree
  1. Mar 31, 2014 #1
    Let the function t(n) be defined recursively by:
    ##t(1) = 1##
    ##t(n) = 3t(\frac{n}{2}) + n + 1## for n a power of two greater than 1.
    Draw several levels of the recursion tree for t, and answer the following:
    What will the height of the tree be if n is a power of 2?
    And what is the sum of values on level 3. assume ##n\geq 16##
    2. Relevant equations
    3. The attempt at a solution
    I did the tree where (n+1) is the root. Each successive level is ##\frac{n+1}{2^k}## with ##3^k## nodes at each height (height =k). So, from my lecture notes to get height I set ##\frac{n+1}{2^k}=1##. I'm sort of stuck here. I do not have the option (it is multiple choice) of ##k=log_2(n+1)## so I must have don't something wrong or I need to manipulate my answer in a way that isn't clear to me.
    For the sum of values I have 3^3 nodes each of value ##\frac{n+1}{2^3}## I thought that I could just say ##3^3\frac{n+1}{2^3}## but this is not an answer either. The closest possible answer was ##3^3n+3^3##
    Thanks for any help!
  3. Mar 31, 2014 #2
    Mark44
    Staff: Mentor
    I don't understand the line above.
    Did you mean this:
    ##t(n) = 3 t(\frac{n}{2}) + n + 1##
  4. Apr 1, 2014 #3
    Yes sorry, i fixed it. I pasted plain text and took them out for some reason.
  5. Apr 1, 2014 #4
    Mark44
    Staff: Mentor
    I would start playing with it. You're given t(1) = 1. What's t(2)? t(4)? And so on. I'm not sure what is meant by "recursion tree" other than how many times the formula will be used to evaluate t(n).
Have something to add?
Draft saved Draft deleted
