1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Recursive formulae
  1. Mar 6, 2008 #1
    [SOLVED] Recursive formulae
    Determine whether each of these proposed definitions is a valid recursive definition of a function f from the set of nonnegative integers to the set of integers. If f is well defined, find a formula for f(n) when n is a nonnegative integer and prove that your formula is valid.
    a) f(0) = 1, f(n) = -f(n – 1) for n >= 1
    3. The attempt at a solution
    f(1) = -f(1 – 1) = -f(0) = -1
    f(2) = -f(2 – 1) = -f(1) = 1
    f(3) = -f(3 – 1) = -f(2) = -1
    I can see that it is a valid recursive definition.
    Why is it asking me to find a formula for f(n), when we were given it (= -f(n-1))?
    Are they asking for a nonrecursive formula that also applies?
    In this case, it would be f(n) = (-1)^n.
    Is this what they want?
  3. Mar 6, 2008 #2
    Yes. It is.
  4. Mar 6, 2008 #3
    How would I "prove" these to be equivalent?
  5. Mar 6, 2008 #4
    You mean prove that f(n) = (-1)^n? Use induction.
  6. Mar 7, 2008 #5
    One of the questions I'm now facing, I can't answer with one formulae. f(2k) = 0, regardless of k, and f(2k+1) keeps doubling. I could possibly use two formulae, one for even, one for odd, but is this what I am to do, or is this considered a "not well defined" function?
  7. Mar 7, 2008 #6
    Consider both even and odd cases as you have already pointed out. Ask yourself this: If it isn't well defined, for what values of the argument is it not well defined?
  8. Mar 7, 2008 #7
    My book says,
    Unsure about "well" defined, but the formula is "defined" for all positive integers.
    For reference, it's:
    f(0) = 1, f(1) = 0, f(2) = 2, f(n) = 2f(n – 3) for n >= 3
    From which, you see at pattern of:
    1, 0, 2, 0, 4, 0, 8, 0, 16, 0, 32, 0, etc.
  9. Mar 7, 2008 #8
    Made a mistake.
    It actually goes:
    Code (Text):
       n = 0, 1, 2, 3, 4, 5, 6
    f(n) = 1, 0, 2, 2, 0, 4, 8
    This makes it even harder to make a formula for.
  10. Mar 7, 2008 #9
    Ben Niehoff
    There is a standard method of solving recurrence relations. Is your course not teaching it? It works like this:
    Try a solution of the form
    [tex]F(n) = r^n[/tex]
    where r is some number yet to be determined. Now, plug this into your recurrence relation, and you will get an algebraic equation for r. For example, suppose you have the Fibonacci sequence:
    [tex]F(n) = F(n-1) + F(n-2)[/tex]
    Plugging in [itex]F(n) = r^n[/itex], we get
    [tex]r^n = r^{n-1} + r^{n-2}[/itex]
    Now, simply divide both sides by [itex]r^{n-2}[/itex] and move everything to the left side to get a quadratic equation in r:
    [tex]r^2 - r - 1 = 0[/tex]
    Solving this for r, you obtain
    [tex]r = \frac{1\pm\sqrt5}2[/tex]
    (note: if you take the plus sign, you get the Golden Ratio!). Now, since you have two different solutions, you can try a linear combination of them:
    [tex]F(n) = Ar_1^n + Br_2^n[/tex]
    In order to find A and B, you use your initial values:
    [tex]F(0) = 1[/tex]
    [tex]F(1) = 1[/tex]
    which will lead to a system of two linear equations to solve for A and B.
  11. Mar 7, 2008 #10
    Ben Niehoff
    Note that if you DID have a sequence like
    [tex]1, 0, 2, 0, 4, 0, 8, ...[/tex]
    then you can proceed by noting that this is a sum of two sequences:
    [tex]\frac12, \frac{\sqrt2}2, 1, \frac{\sqrt8}2, 2, \frac{\sqrt{32}}2, 4, ...[/tex]
    [tex]\frac12, -\frac{\sqrt2}2, 1, -\frac{\sqrt8}2, 2, -\frac{\sqrt{32}}2, 4, ...[/tex]
    and then you can write down the answer as
    [tex]\frac12\left[(\sqrt2)^n + (-\sqrt2)^n\right][/tex]
  12. Mar 8, 2008 #11
    HallsofIvy
    Staff Emeritus
    Divide it into three cases: n= 3k, n= 3k+1, n= 3k+ 2.
  13. Mar 8, 2008 #12
    But the thing is, I only need to do this work if it is "well defined". But, all of the questions seem "well defined", which throws me off =/
    b) f(0) = 1, f(1) = 0, f(2) = 2, f(n) = 2f(n – 3) for n >= 3
    c) f(0) = 0, f(1) = 1, f(n) = 2f(n + 1) for n >= 2
    d) f(0) = 0, f(1) = 1, f(n) = 2f(n – 1) for n >= 1
    e) f(0) = 2, f(n) = f(n – 1) if n is odd and n >= 1 and f(n) = 2f(n – 2) if n >= 2
    They all seem to be valid to me...
    Should I just ignore the "well defined" part and do it anyway?
  14. Mar 8, 2008 #13
    HallsofIvy
    Staff Emeritus
    Well, you could go ahead and try to find a "closed form" formula for f(n). If you can then the recursive formula must be "well defined"!
    In (c), you have "f(0) = 0, f(1) = 1, f(n) = 2f(n + 1) for n >= 2". What is f(2)? How would you find f(3)?
  15. Mar 8, 2008 #14
    f(2) = 2f(3), but we don't have f(3), so we switch things a bit.
    f(n) = 2f(n+1)
    f(n)/2 = f(n+1)
    Which I believe would be the same as f(n-1)/2 = f(n)
    Plug in 2 for n, and you get...
    f(2) = f(1)/2 = 1/2
    For n=3, f(3) = f(2)/2 = 1/4
    So a formula for this could be something similar to [tex]f(0) = 0, f(n) = \frac{1}{2^{n-1}}[/tex] for n [itex]\geq 1.[/itex].
  16. Mar 8, 2008 #15
    HallsofIvy
    Staff Emeritus
    Very nice. But f(n)= 2f(n+1) is only defined for n>= 2 so that f(n-1)= 2f(n) and then f(n)= (1/2)f(n-1) is only defined for n-1>= 2 or n>= 3.
Similar Discussions: Recursive formulae
Loading...
