Reducing EMC on CCA - Strategies and Suggestions
  • Thread starter troberts24
In summary, we have a design which has some radiated emissions exceeding are stated levels. I am looking at the various added inductors added to the power pours and planes. I have not found much information indicating these are helping to reduce our emission levels. I believe these inductors are making our emissions higher. Any other suggestions or comments are welcom
troberts24
We have a design which has some radiated emissions exceeding are stated levels.
We are trying to reduce our emissions profile.
1) We have increased our series termination resistors to "soften" the clock edges
2) I am looking at the various added inductors added to the power pours and planes.
3) We have low value caps on the outputs of our oscillators, these are used in conjunction with
the series resistor as a low pass filter.
Welcome to the PF.
We will need a lot more information to be of help. Can you say more and/or post pictures of your device? Have you read the standard EMC tutorial materials, including the classic book "Noise Reduction Techniques in Electronic Systems" by Ott?
Is this on a breadboard or a PCB? Or is it a chip?
If on a PCB you should separate the analog and digital ground planes.
For specific types of systems you can find lots of discussion and advice. For example this is for PCBs:
http://www.cypress.com/?docID=28761
yes this is a PCB which has been built...Yes we have a ferrite bead on the digital and analog ground plane.
I just do not believe adding ferrite beads on Digital power pours is helping us...
Please post much more information about your device. You are wasting our time with such general questions (sorry to be harsh).
I do not intend to be overly vague... It should actually be a simple answer...I could take a snapshot of the schematic to show the inductors in series with the power pours... I have not located anything on the web to indicate the inductors reduce the high frequency noise.. I believe they are making the problem worse. I was always taught, the power pours should have very low impedance...
Excessive radiated emissions comes from common-mode RF currents that excite resonant antenna-like conducting structures in and around your product. It can be anything from poor "star grounding" to parasitic capacitive coupling of signals into parts of your metal enclosure or external metal.
Sometimes ferrite beads help, and sometimes they don't. It all depends on the PCB layout, the circuitry involved, the frequencies involved, and what the final radiating structure is. Your question is still to vague for me. I will unsubscribe from this thread, and hopefully others will be willing to help you. I'm an EMC expert, BTW.
How many layers? What frequencies? How are you detecting the EMC? Is this a school project or something else?
You seem to think that adding inductors everywhere is the solution. This is only part of the solution, and may not be the solution for your situation.
That is why I posted the particular reference in #3; there is an immense literature on this topic, magazines devoted to it. As with most problems you must examine the system as a whole, and work through all of the details. Here is a tutorial: http://www.learnemc.com/EMC-Tutorials.html [Broken]
Ok, let me add further details..
We have 24MHz and 27MHz crystals in the design, they both have 33 ohm series resistors at the output.
The crystals are as close to the IC as possible. Our product is audio and video based... We have RE violations
up to the 7th harmonic of these base frequencies.. Our design uses a 6 layer board.. Our digital signals are coupled to an adjacent plane with ground copper plane and power plane... I am suggesting various things to reduce the emissions short of a new PWB design.. One possible reduction is to remove there small inductors added to the LDO and switcher outputs... I do not believe they are needed...
Tom
Don't use inductors on the power lines. Use ferrite beads. As for inductors making things worse, it is hard to say. An inductor feeding a large enough capacitor (with small caps also) will keep high frequency currents out of the supply. The low impedance comes from the bypass capacitors.
Are there cables involved besides the power cables, and what happens to emissions when they are disconnected?
Are your violations at all related to the switcher? Does it have adequate snubbing?
What sort of case is this in?
How are the power grids layed out and bypassed (ground is more important)? Are there local 0.1uF bypasses at all IC's?
Are the clock layed out as transmission lines? Always over a ground plane?
Are there sufficient grounds in any cables?
Berkeman is correct, this type of issue cannot be productively discussed without a certain minimum critical mass of information.
If you indeed have separate analog and digital ground planes this would be what I would suspect first. If you have a way of bonding them together try that first.
1. How does electromagnetic interference (EMI) affect circuit boards?
EMI can cause disruptions or malfunctions in electronic devices by introducing unwanted signals or noise to the circuit board. This can lead to poor performance, data errors, or even complete failure of the device.
2. What are some common sources of EMI?
Some common sources of EMI include power lines, radio and TV broadcasts, cell phones, computers, and other electronic devices. EMI can also be generated internally within a circuit board due to high-speed switching signals.
3. What are some strategies for reducing EMI on circuit boards?
Some strategies for reducing EMI on circuit boards include using proper grounding techniques, shielding sensitive components, reducing the length of high-speed signal traces, and minimizing the use of long parallel traces.
4. How can capacitors be used to reduce EMI?
Capacitors can be used to filter out high-frequency noise on a circuit board. Placing a capacitor between the power supply and the ground can create a low-impedance path for the noise to be diverted, reducing its impact on the circuit board.
5. Are there any design guidelines for reducing EMI on circuit boards?
Yes, there are several design guidelines that can help reduce EMI on circuit boards. These include minimizing trace lengths, using proper grounding techniques, keeping sensitive components away from noisy components, and using proper spacing between traces and components to avoid signal coupling.
  • Electrical Engineering
11K
14K
  • STEM Academic Advising
  • Astronomy and Astrophysics
Writing: Input Wanted Great Lakes Earth Map
