Reduction of Order Equation
  • Thread starter Destroxia
t^2*y^'' -t(t+2)y^' + (t+2)y=0 , t>0; ysub1(t) = t
Reduction of order:
A second solution is assumed to be of the form:
ysub2(t) = v(t)*ysub1(t)
So, the algebra in the first part of the process seemed to be correct, as it cancelled out all the "v" terms and left only derivatives of v. The problem seems to happen somewhere around when I turn it into a first order linear equation and attempt to multiply through by an integrating factor. As far as I, and a CAS are concerned, that integral at the end is not possible to take. This leaves the assumption that I completely goofed up my integrating factor. Where could I have gone wrong?
Answers and Replies
7,273
Reduction of order:
I don't think so. After substituting y2(t) = tv into the differential equation, and simplifying, I ended up with this equation:
##t^3v'' - t^3v' = 0##, which is pretty easy to solve.
I'm pretty confident that this is correct, as I went ahead to find ##y_2## and found that it satisfied the diff. eqn.
Okay, I re-did all my algebra and I made the mistake somewhere distributing in the middle term. Thank you for your help.
Related Threads on Reduction of Order Equation
20K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
