- 3
How much of a wall 3m behind you can be observed in a 5 cm square mirror which is held centrally at a distance of 10 cm from your eye?
None that I can think of. I think this is straight geometry.
I know I have to use similar triangles but don't understand why. What's the rule of thumb for using similar triangles? Is it because the eye is in common between the wall and mirror? How do I know the two triangles share the same angles?
This is the answer in the book:
Let the highest part of the wall able to be seen be x metres above the top of the mirror.
From similar triangles:
X/300 =2.5\10
X=75 cm
You can see a square of the wall of length 75+5+75=155cm
Now I think I understand why the second similar triangles side length is 2.5cm ( the mirror was placed centrally hence 5cm/2) but can you explain why 75 is added twice and then to the length of the full mirror in the last part? I'm really lost.
Any help would be appreciated. Thanks!
[/B]
