Refrigerating a sealed room?
  • Thread starter Artlav
Seems like a pretty basic thermodynamics question, but i can't think of a way how or get a clear reason why not.
Let's take a heat-insulated room with a usable energy source provided in it (electric wires sticking out of a wall).
Can this room be refrigerated as a whole?
One thing is, any refrigeration scheme i've seen requires a heat sink besides a power source, so one half of the room would have to be made hotter to get the other half colder, and since whatever way is used would add more heat to what it moves, the overall temperature would increase until the power runs out. First law of thermodynamics.
On the other hand, why can all the excess of heat/entropy be generated on the other side, where the energy source is? Energy can be use to order things, and ordering things reduce entropy. There are ways to slow atoms down directly on small scale.
So, is it a fundamental or technical problem?
Mapes
It's a fundamental problem. To cool the room, you need to remove entropy as well as energy, and the heat insulation prevents the entropy from leaving.
5,598
39
If it were theoretically possible to do what your suggest, room air conditioners would not have to be hung out windows to get rid of extra heat...
But if you had a water supply coming into the room instead of electricity with water colder than the room, and allowed the water to leave the room, you of course could cool the room.
162
Thank you for clarifying.
Yesterday i would have agreed and not asked the question above, but today i've been to one official's office, which is quite like the room described - heat insulated and with windows that don't open (after all the usual problem here is -30C, not +40C). And there on a cabinet stood a small AC unit, the kind you stick into a window leaf, blowing cold air on the clerk in question. The thing had the hot end in the same room it was cooling, yet there was a stream of cold air, and the rest of the room was only marginally hotter than outside.
That got me thinking.
Integral
Staff Emeritus
54
Sure, the fellow sitting right in front of the cool air flow will feel cooler. HOWEVER, the room as a whole will be hotter.
2,193
I don't think that was a standard air conditioner. If it were... dumb, de dumb, dumb.
Not only would it NOT cool the room, it would heat it up. Like said before, a person directly in front of it might expierience a cool air flow, but the entire room would actually get hotter.
Assuming the "not dumb" factor, the unit might have been an indoor swamp cooler as oppossed to a regular window mounted air conditioner.
Note that, even with an indoor swamp cooler, you MUST crack a window open, preferably in the same room.
Even still, a simple fan will cool someone in front of it, yet will ADD heat to the rest of insulated room.
Andrew Mason
7,485
283
You should go back to his office and find out how it worked. All we can say is that it has to be putting out more heat than it absorbs (ie. if the hot reservoir is the room, it heats the room more than it cools).
AM
russ_watters
Mentor
18,405
4,651
Assuming the "not dumb" factor....
Ugh, unfortunately, the "not dumb" factor is not a safe assumption.
A few years ago, my company was hired to help my alma matar (!) [hangs head in shame] deal with an overheating data center. The college had been growing and as a result they had been packing their primary data center with new servers to handle the email and network storage of new students/profs/classes. When I went to survey, I found they had been doing their own cooling upgrades in an attempt to keep ahead of the rising heat load. The installed systems, in order of installation, were:
1. Standard Computer Room Air Conditioning (CRAC) units. These have air handlers in the data center that blow cold air under a raised floor, where it percolates up through perforated floor tiles. Air is returned through the top of the unit, directly from the room. The heat is rejected to remote (outside) condensing units like what you have sitting outside your house. Standard, straightforward.
2. Operating on a similar theory, they added a large residential grade split system to dump cold air into the floor plenum and pull warm air from the ceiling plenum. The ceiling also had perforated ("eggcrate") tiles to allow the hot air rising off the servers up into the ceiling. Again, a remote condensing unit rejected the heat to outside. I believe it had 17.5 kW (5 tons) of cooling capacity.
This wasn't sufficient so you know where this is going.....
3. For hotspots that were cropping up in the room, they added a handful of spot coolers. These are completely self contained units - no separate unit that sits outside for heat rejection. They use a duct that pulls a little bit of air from the room to cool the integrated condenser, then you are supposed to run that duct to a window to dump the waste heat outside. Instead, they ran the heat rejection duct up to the ceiling. I think there may have been three of these units, producing 3.5 kW of cooling each, while requiring 1.5 kW of input each, for 3.5+1.5=4 kW of heat rejection each.
So what they "gained" here is instead of letting the fan of the system in #2 pull warm air up into and through the ceiling plenum as it was already doing, they added 4.5 kW of "pumps" to pump it up there. The net result is the combination of 2 and 3 was 17.5-4.5=13 kW of cooling. Adding #3 decreased the cooling to the data center. And they were genuinely confused about why they were losing control of the temperature even while adding more A/C units.
Duh.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
