Homework Help: Regression line on origin
  1. May 23, 2017 #1
    A random sample of size ##n## from a bivariate distribution is denoted by ##(x_r,y_r), r=1,2,3,...,n##. Show that if the regression line of ##y## on ##x## passes through the origin of its scatter diagram then
    $$\bar y \sum^n_{r=1} x_r^2=\bar x\sum^n_{r=1} x_r y_r$$ where ## (\bar x,\bar y)## is the mean point of the sample.
    I don't really know how to begin. I am aware the line equation is $$b=\frac{y}{x}=\frac{\sum xy-\frac{\sum x\sum y}{n}}{\sum x^2-\frac{(\sum x)^2}{n}}$$
    Not sure what to do next.
  3. May 23, 2017 #2
    Ray Vickson
    (1) Do not write ##\xbar##, write ##\bar{x}##. Right-click on the formula to see its TeX commands.
    Mod note: Fixed the TeX in the original post and above.
    (2) What can you say about the data if the least-squares line has intercept ##a## equal to zero?
  4. May 23, 2017 #3
    Y is proportional to X
  5. May 23, 2017 #4
    Ray Vickson
    That answer is not useful. Take the formula for ##a##, in terms of ##(x_i,y_i)##, and set it to zero. What do you get?
  6. May 24, 2017 #5
    SammyS
    Staff Emeritus
    I suppose the that the linear model you are working with is: ##\ \displaystyle y=a+bx\ ##.
    You have the correct expression for finding the linear coefficient, ##\ b\,.\ ##( Leave out the ##\ \displaystyle \frac yx\ ## ).
    It seems to me that you must also consider the expression for ##\ a\,.\ ## Then show that if ##\ a=0\,,\ ## then you obtain the desired result:
    ##\displaystyle \bar y \sum^n_{r=1} x_r^2=\bar x\sum^n_{r=1} x_r y_r ##​
Have something to add?
Draft saved Draft deleted
