Regularized Green's function
In summary, the conversation discusses the possibility of regularizing a Green's function in coordinate space. The Green's function for a circle of radius R and source located at \vec x_0 is given by a specific formula, which diverges for \vec x=\vec x_0. The speaker mentions the idea of subtracting the divergence to regularize the function and asks if this approach is rigorous. They also inquire about the reason for wanting to regularize the function.
Einj
470
59
Hello everyone,
I would like to know if there is a known, rigorous way to regularize a Green's function in coordinate space. In particular, it is known that the Green's function for a circle of radius R and source located at [itex]\vec x_0[/itex] is given by:
G(\vec x,\vec x_0)=\frac{1}{2\pi}\ln\left[\frac{\left|\vec x-\vec x_0\right|}{\left|\vec x-\frac{R^2}{|\vec x_0|^2}\vec x_0\right|}\frac{R}{|\vec x_0|} \right],
and therefore for [itex]\vec x=\vec x_0[/itex] diverges as [itex]\frac{1}{2\pi}\ln\left|\vec x-\vec x_0\right|[/itex]. Is there any rigorous way of regularizing this function? The most natural way that is coming to my mind is clearly to subtract the divergence by simply defining:
G_R(\vec x,\vec x_0)=G(\vec x,\vec x_0)-\frac{1}{2\pi}\ln\left|\vec x-\vec x_0\right|.
Am I right? Is this rigorous?
Thanks a lot!
Likes DuckAmuck
What do you mean by "regularize" it, and why do you want to do it? We usually expect Green's functions to be singular at the source location.
1. What is a Regularized Green's function?
A Regularized Green's function is a mathematical concept used in the field of mathematical physics. It is a solution to a partial differential equation that represents the response of a system to a point source of energy. It is used to solve boundary value problems and model physical phenomena such as heat transfer, electromagnetism, and fluid flow.
2. How is a Regularized Green's function different from a standard Green's function?
A Regularized Green's function is essentially a modified version of a standard Green's function. It is regularized by introducing a damping or smoothing parameter to prevent the function from becoming infinite at the source point. This allows for more accurate and stable solutions to be obtained when solving boundary value problems.
3. What is the purpose of using a Regularized Green's function?
The use of a Regularized Green's function allows for the solution of boundary value problems where the standard Green's function may fail due to singularities or instabilities. It also allows for the modeling of more complex physical phenomena that require a smoother response from the system.
4. How is a Regularized Green's function calculated?
A Regularized Green's function is typically calculated using numerical methods such as finite difference or finite element methods. It involves solving the original partial differential equation and then applying the regularization technique to obtain a stable and accurate solution.
5. What are some applications of Regularized Green's functions?
Regularized Green's functions have a wide range of applications in various fields such as physics, engineering, and geosciences. They are used to solve problems related to heat transfer, electromagnetism, fluid flow, acoustics, and seismology. They are also used in the development of mathematical models for complex systems and in the design of various technologies such as antennas, sensors, and medical devices.
  • General Math
  • Classical Physics
  • Linear and Abstract Algebra
  • General Math
