Related Rates: Kite String Angle Change
In summary, the problem involves a kite 100 ft above the ground moving horizontally at a speed of 8 ft/s. The question asks for the rate at which the angle between the string and the horizontal is decreasing when 200 ft of string has been let out. By using the equation tanφ = y/x (where y is constant and x is variable) and taking the derivative with respect to time, we can find the rate of change of the angle. By substituting the given values and solving for d(φ)/dt, we can determine the answer to the question.
Brandon_R
A kite 100 ft above the ground moves horizontally at a speed
of 8 ft!s. At what rate is the angle between the string and the
horizontal decreasing when 200 ft of string has been let out?
tan [tex]\o[/tex] = [tex]x/y[/tex]
After solving for the sides of the triangle i got X = 173.21, Y = 100 and Z = 200 and [tex]\o[/tex] = 1.047 rads
then i took the derivative of the equation that links [tex]\o[/tex] with the opposite and adjacent of the triangle and plugged in the variables which gave me:
I got [tex]d\o/dt = .055 rad/sec[/tex]
String mαkes an angle φ with horizontal.
Hence tanφ = y/x, where y is constant and x is variable.
When the string in overhead, the length of the string is 100 ft. 200 ft of string is let out. So the final length of the string is 300 ft.
Taking the derivative on both the side, with respect to time, you get
(-y/x^2)(dx/dt) = sec^2(φ)(dφ/dt)...(1)
sec^2(φ) = 1 + tan^2(φ) = 1 + (y/x)^2
L = 300 ft, y = 100 ft. find x. dx/dt is given. Substitute these values in eq.(1) and find d(φ)/dt
1. What is the "Kite Problem" in related rates?
The "Kite Problem" is a classic example in related rates that involves a kite flying in the air. It usually involves finding the rate of change of one of the sides of the kite in relation to the rate of change of another side.
2. How do you set up a related rates problem involving a kite?
To set up a related rates problem involving a kite, you usually need to identify the variables involved and their rates of change. Then, you can use the Pythagorean theorem and other geometric formulas to create an equation that relates these variables. This equation can then be differentiated with respect to time to solve for the desired rate of change.
3. What are some common mistakes in solving the "Kite Problem" in related rates?
Some common mistakes in solving the "Kite Problem" include not correctly identifying the variables and their rates of change, using the wrong formula, and not properly setting up the equation. It is also important to pay attention to the units of measurement and ensure they are consistent throughout the problem.
4. Can the "Kite Problem" be solved using different methods?
Yes, the "Kite Problem" can be solved using different methods such as using similar triangles, trigonometric functions, or the chain rule. The method used will depend on the specific problem and the information given.
5. How does the "Kite Problem" relate to real-life situations?
The "Kite Problem" is a practical application of related rates and can be used to solve real-life problems involving changing variables. For example, it can be used to calculate the speed of a kite or the rate at which its height is changing. It can also be applied to other situations involving moving objects, such as cars or airplanes.
