fogvajarash
- 127
A kite 100 ft above the ground moves horizontally at a speed of 8 ft/s. At what rate is the angle between the string and the horizontal decreasing when 200ft of the string has been let out?
I've tried two different methods to come up with the answer but I'm not sure which one is correct.
In one case, I've got:
cosθ = x/200
And in the other one:
tanθ = 100/x
However, when I try to derive both sides of both equations in order to get the result, I found out that the values of dθ/dt are actually different for each equation. For example, in the first case:
-sinθ (dθ/dt) = 1/200 (dx/dt)
Clearing this out makes the final result as (-2/25)
On the other hand:
sec2 (dθ/dt) = -(dx/dt) / 3
Clearing this out makes the final result as (-1/50)
Is there a reason for this incongruity or have I made a mistake in my calculations? Thank you very much guys.
