Related Rates Question: Finding Distance Increase with Cosine Law
In summary, a plane flying at a constant speed of 4 km/min passes over a ground radar station at an altitude of 14 km and climbs at an angle of 40 degrees. Using the cosine law and the right triangle relationship, we can find the rate at which the distance from the plane to the radar station is increasing 3 minutes later. By differentiating the right triangle equation with respect to time and using the fact that the plane's acceleration is zero, we can solve for this rate.
CalXeon
A plane flying with a constant speed of 4 km/min passes over a ground radar station at an altitude of 14 km and climbs at an angle of 40 degrees. At what rate, in km/min is the distance from the plane to the radar station increasing 3 minutes later?
The only equation I am using is the cosine law:
c^2=a^2+b^2-2abCos(Angle)
a=14
b=(i am not sure if its 4 or not)
I have been doing this:
c^2= 14^2+ b^2- 2(14)b cos(130)
But I can't seem to get the answer, Please help me out
When you say "climbs at an angle of 40 degrees," I assume you mean with respect to the ground. If this is the case, then you'll have a right triangle where the vertical displacement is 14km, call it "a," the plane's horizontal displacement is 14/tan(40), call it "b," and the plane's displacement with respect to the radar station is 14/ sin(40), call this "c." The right triangle relationship gives us:
[tex] a^2 + b^2 = c^2 [/tex].
You need to differentiate both sides of this equation with respect to time. When you do this, you'll have the three displacements stated above, and you'll have three rates of change (one rate of change with respect to each variable), one of which you'll be solving for. To find the two known rates of change (as opposed to the one you're solving for), you'll want to use the fact that the acceleration of the plane is zero both vertically and horizontally, and thus you can use the equation distance = rate*time. After this, you should only have the one unknown to solve for.
1. What is the cosine law and how is it related to related rates problems?
The cosine law is a mathematical formula used to find the length of a side of a triangle using the measures of its other sides and the angle between them. It is related to related rates problems because it can be used to find the rate of change of a side length in a triangle as one of the other sides or the angle changes.
2. How do you set up a related rates problem involving the cosine law?
To set up a related rates problem using the cosine law, you first need to identify the variables involved. This includes the changing variable, the related variable, and any constant values. Then, you can use the cosine law to create an equation involving these variables, and take the derivative with respect to time to find the rate of change.
3. What are some common real-life applications of related rates problems using the cosine law?
Related rates problems involving the cosine law can be applied to situations where two objects are moving towards or away from each other at constant speeds and the angle between them is changing. For example, this can be used to calculate the rate at which a car is approaching a traffic light or the rate at which a plane is changing direction as it flies towards a destination.
4. Can the cosine law be used to solve related rates problems with non-right angled triangles?
Yes, the cosine law can be used to solve related rates problems involving any type of triangle, whether it is right-angled or not. However, in non-right angled triangles, the angle between the sides may change as the sides change, making the problem more complex to solve.
5. What are some tips for solving related rates problems involving the cosine law?
One tip is to draw a diagram of the situation and label all the involved variables. This can help you visualize the problem and identify any relationships between the variables. Another tip is to carefully read the problem and identify what is changing and what is constant. Finally, it can be helpful to use the Pythagorean theorem in combination with the cosine law to solve for unknown variables.
9K
