Related Rates: Water Trough Volume and Rate of Change
In summary, to find the rate at which the water level is rising in a water trough, we use the formula V = (1/2)·b·h·L, where b is the base of the isosceles triangles at the ends of the trough, h is the height of the water, and L is the length of the trough. By using similar triangles, we can find the base of the water and then use the formula V = (1/2)·b·h·L to solve for the rate of change of the water level, which is represented by dh/dt. In this case, the rate of change of the water level is .04 ft/min.
rocomath
1,755
Related Rates - Is my set-up correct?
A water trough is 10ft long and its ends are isosceles triangles that are 3ft across the top and have height 1ft. If [tex]\frac{dV}{dt}=12\frac{\mbox{ft}^{3}}{\mbox{min}}[/tex], how fast is the water level rising when the water is 6 inches deep?
[tex]V=\frac{1}{2}(b_1 + b_2)h \rightarrow \frac{1}{2}[b_1 + (b_1 + 2r)]h[/tex]
... By similar triangles [tex]\frac{3}{1}=\frac{r}{h} \rightarrow r = 3h[/tex]
[tex]V=\frac{1}{2}(20+6h)h \rightarrow (10+3h)h[/tex]
[tex]\frac{dV}{dt}=(10+6h)\frac{dh}{dt}[/tex]
Is this correct so far?
I'm not sure I understand your choice of a volume formula. The trough is a triangular prism with its long axis (10') horizontal and its triangular cross-sections (base: 3', height: 1') oriented apex downward. The critical issue here is that your formula only has two dimensions of length and seems to be the formula for the area of a trapezoid...
Well I looked at the SM of the following problem b/c I wasn't sure what a trough was, and that is the same picture they used :-\
Did you look up the definition of "trough" in a dictionary? I suspect in the "following problem", they specified that the ends of the trough were trapezoids since you are trying to work with two bases. In this problem, it is specified that the ends are isosceles triangles. That's the difficulty with just "mimicing" another problem solution.
The volume of water is the end area times the length of the trough. The end of the whole trough is an isosceles triangle with height 1 and base 3: its area is (1/2)bh= (1/2)(3)(1)= 3/2 square feet. The water in the trough is a triangle "similar" to the entire triangle. You can get its base, and then area, by using the fact that "corresponding" sides are in the same proportions.
I would still need to take into consideration that it has 2 bases, right?
[tex]V=A(b_1 + b_2)[/tex]
A = the isosceles triangles, which has units squared which multiplied with the bases will give a cubic.
The third dimension of the trough, which is a triangular prism, is simply the length of the trough. So the volume should be V = (1/2)·b·h·L . For your related rates problem, L will be the constant 10 feet. The trough is being filled from the apex of the triangle upward, so the current "height" of the volume of water will be h and the base will be given by the relation you already found. The filled volume will itself always be a triangular prism.
(It's somewhat amusing that, in an age where the great majority of people live in cities, there are still problems based on water troughs, which hardly anyone outside of rural areas have seen much.)
What two "bases" are you talking about? The ends are triangles and the "3 feet" is the base of those triangles. The only other number given is the 10 foot length. The area of the end triangles is (1/2)(3)(1)= 3/2 square feet. The volume of the entire trought is that area times the length: (3/2)(10)= 15 cubic feet.
NOW, you need to do the actual problem. If the water in the trough has height 6"= 1/2 foot, what is its volume? The length of the trough is still 10 feet, the height is now 1/2 foot and you can get the length of the base by using "similar triangles".
I have the answer!
what we have:
dv/dt = 12
h = .5 ft.
l = 10 ft
what we want:
dh/dt
v = .5bhl
v = .5bh*10
v = .5(3h)10h
v = 15h^2
dv/dt = 30h*dh/dt
dh/dt = dv/dt / 30h
dh/dt = 12/30(10)
dh/dt = 12/300
dh/dt = .04 ft/min.
The height is changing at a rate of .04 ft/min.
What is the concept of "Related Rates"?
Related rates is a mathematical concept that deals with finding the rate of change of one variable with respect to another variable, when the two variables are related by an equation.
How do you set up a related rates problem?
To set up a related rates problem, you need to identify the variables involved and determine how they are related by an equation. Then, you need to take the derivative of the equation with respect to time and substitute the given values to solve for the unknown rate of change.
What are some common scenarios where related rates are used?
Related rates are commonly used in real-world scenarios involving geometric shapes, such as changing dimensions of a cylinder or cone, or in situations involving rates of change, such as the speed of a moving object or the rate at which a tank is filling with water.
What are some tips for solving related rates problems?
Some useful tips for solving related rates problems are to draw a diagram to visualize the situation, use appropriate units for all variables, and review basic calculus concepts such as the chain rule and implicit differentiation.
Can related rates problems have multiple solutions?
Yes, related rates problems can have multiple solutions. This can happen when there are multiple variables involved in the problem, or when there are multiple equations that can be used to relate the variables. It is important to carefully consider the given information and choose the appropriate equation to solve for the desired rate of change.
