1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Relative Change
  1. Nov 1, 2005 #1
    Hello All
    I have this problem that I have no idea how to do.
    F = flux or the volume of blood to flow past a point
    R = radius
    F=kR^4
    Show that the relative change in F is about four times the relative change in R. How will a 5% increase in radius affect the flow of Blood??
    How in the world do I do this?? What is Relative Change?? My text book does not have this term
    I think I need to have 2 equations F = kR^4 and R = (F/k)^(1/4). Not sure what to do.
    Please help.
  3. Nov 1, 2005 #2
    Tide
    Relative change is the ratio of how much a quantity changes to its starting value.
    In your problem, F varies as the 4th power of R which you wrote as [itex]F = k R^4[/itex]. Here's one way to get the needed "formula."
    Clearly, if F changes, there will be a corresponding change in the value of R and vice versa. Suppose these changes are [itex]\delta F[/itex] and [itex]\delta R[/itex]. Using the relation between F and R, those changes result in
    [tex]F + \delta F = k \left(R + \delta R\right)^4[/tex]
    Now expand the expression on the right (we don't have to do the whole thing because we're going to assume that the changes are small!) so we have, approximately
    [tex]F + \delta F = k \left(R^4 + 4 R^3 \delta R + \cdot \cdot \cdot\right)[/tex]
    Snce [tex]F = k R^4[/itex] those two terms cancel and to first order in the small variations we find
    [tex]\delta F = 4 k R^3 \delta R[/tex]
    Finally, divide both sides by [itex]F = k R^4[/itex] so that
    [tex]\frac {\delta F}{F} = 4 \frac {\delta R}{R}[/tex]
    which compares the relative error in F to the relative error in R. We could have accomplished the same thing using calculus but I wasn't sure if that is in your toolkit.
  4. Sep 29, 2009 #3
    This post is pretty old but I came across the same problem. Using calculus, the relative change would be
    F'(R)/F(R)
    if F(R) = kR^4, then F'(R) = 4KR^3 dR
    So the relative change is:
    4kR^3 dR
    kR^4
    What you are left with is
    4 * (dR/R)
    This means that the relative change in F is 4 times the relative change in R.
    Now, if there is 5% increase, then the change in radius is dR/R = 5% = 0.05. So you would plug that back into your relative change equation:
    4 * (0.05) = .2 = 20%
    If there is a 5% increase in the radius, then the flow increases by 20%. Which follows that the relative change in F (20%) is 4 times the change in radius ( 4 * 5%).
    Is this forum LaTeX supported?
Similar Discussions: Relative Change
  1. Relative Change (Replies: 6)
Loading...
