Relative motion and light
Main Question or Discussion Point
In an ideal environment, if a light source is moving directly away from you at the speed of light will the light act like an object that is acted upon by two opposing forces and stand still? Would we be able to see the light source? Thanks!
Secman
Answers and Replies
jtbell
Mentor
15,484
3,253
That's not possible, even in an ideal experiment.
Which part? The speed of light part? If so can we assume it's possible for this system?
jtbell
Mentor
15,484
3,253
Yes.
If we do this, we can't use relativity to make predictions about the consequences.
ghwellsjr
146
Secman
If you assume that it's possible for your system, then you get to make up your own laws of physics and you can make up anything you want. No one is going to be able to second-guess what you might dream up. But you're not allowed to speculate on such matters on this forum. This forum is to learn about relativity and how it explains the real world, not to pretend that the world is different so you can make up your own fantasy.
Nugatory
Mentor
12,504
4,998
As phrased, the question has no answer, as there is no such thing as a light source "moving directly away from you at the speed of light". However, there is a very closely related question which does make sense and does have an answer:
In an ideal environment, if a light source is moving directly away from you at almost (say 99.99999999999999999999%) the speed of light will the light act like an object that is acted upon by two opposing forces and stand still? Would we be able to see the light source?
And the answer is:
1) No, the light will not almost stand still. In a vacuum, light travels at the speed c regardless of the velocity of the source or the target.
2) Because of the first answer, yes, the light will get to you so you'll be able to detect it. The light will be red-shifted, and if it's red-shifted enough it won't register on your eyes, so you may not be able to literally "see" the light source, but if you have the right instruments (for example an infra-red night vision device for moderate red-shifts) you will be able to detect it.
Matterwave
326
I'd like to point out that the OP said only "light source" and never mentioned anything about a flashlight or some-such thing that has mass.
It requires a bit more, then, than simply the axioms of special relativity to rule out the possibility of a massless particle (moving away from you) decaying into more massless particles (one of which is moving towards you). Perhaps momentum or energy conservation prevents this, but I cannot confirm this without taking out a pen and paper...especially if we include the possibilities of many (n-particle) decays.
At a more fundamental level, perhaps quantum field theory prevents such decays?
EDIT: I had not considered the red-shift effect. Perhaps that itself would prevent this decay since any potential photon emitted would be red-shifted to 0-frequency.
Related Threads for: Relative motion and light
