What direction will a man appear to be rowing in relative motion?
In summary, the man should row at 53.1 degrees upstream when the water is moving at 1.5m/s. For observers on the land and in the boat, the motion of the boat will appear to be crossing the river. However, for an observer co-flowing with the river, the boat's velocity will be its velocity in the co-flowing frame of reference plus the velocity of the co-flowing frame relative to another observer's frame. The resultant velocity is perpendicular to the river current.
medwatt
123
Hello,
If a man how is able to row on still water at 2.5m/s. If the water is moving at 1.5m/s, in which direction should he row.
The answer is he should row at 53.1 degrees upstream but the question for an observer on the boat and another observer on land, how will the motion appear?
For an observer on land will the man appear to be rowing along a perpendicular to both river banks ?? Or is it for an observer flowing smoothly with the river current ??
Hence I would like to know how is motion will look like from three different points, from the land, from the water and from the boat !
Thanks !
The observer co-flowing with the stream and the observer on the land will be observing the motion of the boat, that is clear.
But what is the observer on the boat going to observe?
The thing that is bothering me is with respect to an observer flowing with the river due east it will appear that the boat will be going vertically upstream. Of course the observer on the boat knows where he is going (2.5m/s at 53.1 degrees upstream. My question is on the ground/bank, what will a stationary observer see ? Surely he can't see either of the two cases mentioned above ??
The co-flowing observer cannot just see that the boat is going strictly against the stream. In the end, the boat DOES cross the river, and that will be seen by any observer.
In any case, the observed velocity of the boat is its velocity in the co-flowing frame of reference plus (vector plus!) the velocity of the co-flowing frame relative to whatever frame the other observer is in.
But if you draw a vector diagram the resultant of the boat and the river current, you will notice that the river current and the relative velocity vector are perpendicular !
The relative velocity is not perpendicular. It is at 53.1 degrees. The resultant velocity is perpendicular.
1. What is relative motion?
Relative motion refers to the movement of an object with respect to another object. It is the measurement of an object's position, speed, and acceleration in relation to a reference point or frame of reference.
2. How is relative motion different from absolute motion?
Absolute motion refers to an object's movement in relation to a fixed point, such as the Earth's surface. Relative motion, on the other hand, considers the movement of an object in relation to another moving object.
3. How do you calculate relative motion?
To calculate relative motion, you need to determine the velocity and acceleration of an object in relation to a reference point. This can be done by subtracting the velocity and acceleration of the reference point from the velocity and acceleration of the moving object.
4. What is the importance of relative motion in science?
Relative motion is an important concept in science as it helps us understand the movement of objects in relation to one another. It is used in fields such as physics, astronomy, and engineering to describe the motion of objects and how they interact with each other.
5. Can relative motion be observed in everyday life?
Yes, relative motion can be observed in everyday life. For example, when you are riding a train and looking out the window, the trees and buildings may appear to be moving past you. This is because of the relative motion between the train and the stationary objects on the ground.
