Relative Speed of 2 Beam Lights: Is it C or Zero?
In summary, the question is about the relative speed of two light beams moving in the same direction. While the velocity addition formula suggests the relative speed would be zero, the concept of being at rest relative to light is impossible. Additionally, the law of velocities addition cannot be applied in this scenario because it is derived under the assumption that the relative speed is not equal to the speed of light.
sayf alawneh
here "c" is the speed of light ,
i have a question in my mind and i have no answer for it ,
if two light beams are moving in opposite directions then their relative speed is simply c using the law of velocities addition in case of special relativity
but what if those two light beams are moving in the same direction will their relative speed be also c or zero
it seems to be zero using the law of velocities addition but my friend claims that it should be c , is that true and how can it be c logically
Are you asking how fast a beam of light travels from the perspective of another beam of light?
The answer is that there is no answer, because light doesn't have a "perspective."
In order to speak of how fast something is traveling relative to an observer, it must be possible (in principle) to measure the speed of that something when you're at rest relative to the observer. But we can never be at rest relative to anything that travels at ##c##. Light simply cannot be an "observer."
Likes Orodruin
Also note that the velocity addition formula yields 0/0 for the relative velocity of two light beams in the same direction, telling you there is a problem.
what if i am riding one of the light beams ?
in other words if i am riding one of the beams that moves in the same direction of another beam what will be the speed of the other beam ?
You can't travel at the speed of light unless you're a massless object , in which case you can only travel at the speed of light.
You can't. If you were "riding a beam of light", then you would be moving at the same speed as that beam of light so its speed relative to you would be zero - but that's impossible because the speed of light is always ##c## for all observers.
No, it isn't. That law relates the speed in one frame to the speed in another, given the relative speeds of the two frames. That relative speed cannot be ##c##. The conditions under which the law is derived forbid it. In other words, if it were indeed possible for one frame to have a speed ##c## relative to another that law wouldn't be valid.
1. What is the relative speed of two beam lights?
The relative speed of two beam lights can vary depending on the reference point. However, according to the theory of relativity, the relative speed of two beam lights is always measured to be the same, regardless of the reference point.
2. Is the relative speed of two beam lights constant?
Yes, according to the theory of relativity, the relative speed of two beam lights is always constant. This means that no matter how fast an observer is moving relative to the light sources, the relative speed between the two beam lights will always be the same.
3. What factors can affect the relative speed of two beam lights?
The only factor that can affect the relative speed of two beam lights is the speed of the observer. This is because the speed of light is constant and cannot be altered by any other external factors.
4. How is the relative speed of two beam lights determined?
The relative speed of two beam lights can be determined by measuring the speed of the observer and the speed of light, and then using the formula v = c - u, where v is the relative speed, c is the speed of light, and u is the speed of the observer.
5. Is the relative speed of two beam lights always the same as the speed of light?
No, the relative speed of two beam lights can be different from the speed of light depending on the speed of the observer. However, the relative speed will always be constant and will never exceed the speed of light.
