Relative velocity
  1. Jul 20, 2017 #1
    2. Relevant equations
    3. The attempt at a solution
    The water skier makes an angle of 20 deg with the axis of the boat. I do not understand how to get the other angles.
  3. Jul 20, 2017 #2
    mfb
    2016 Award
    Staff: Mentor
    Which angle do you want to find?
  4. Jul 20, 2017 #3
    Apparently, you need to assume that the skier is moving perpendicular to his tow line.
    That is, his total velocity is perpendicular to the tow line even tho his linear velocity (parallel to the boat)
    is at 50 deg.w.r.t. the tow line.
  5. Jul 21, 2017 #4
    I need to correct the above statement "his total velocity is perpendicular to the tow line".
    A person riding in the boat would see the skier moving perpendicular the tow line.
    That velocity then has to be added to the velocity of the boat to get the skier's total velocity.
    Using geometry and the angles given you can construct the velocity triangle and solve with the Law of Sines.
  6. Jul 21, 2017 #5
    mfb
    2016 Award
    Staff: Mentor
    I'm quite sure the person is moving along the length of the skier (relative to the water). (a) because that's how they work and (b) otherwise giving their direction would be pointless.
  7. Jul 21, 2017 #6
    I agree that skier is moving at 20 deg to the path of the boat.
    Since he is at a fixed radius (10 m) from the boat his instantaneous path w.r.t an observer
    on the boat must tangential w.r.t that radius.
    That assumption agrees with the answer (a) of 80.8 m/s but it doesn't agree
    with the answer for part (b)???
  8. Jul 22, 2017 #7
    haruspex
    2016 Award
    Did you forget to convert from kph to m/s?
  9. Jul 22, 2017 #8
    Thanks. I agree with the given answer.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Relative velocity
  1. Relative velocity (Replies: 3)
  2. Relative velocity (Replies: 3)
  3. Relative velocities (Replies: 1)
  4. Relative velocity (Replies: 4)
Loading...
