Relativistic centripetal force
  • Thread starter yuiop
  • #176
1,568
It isn't that hard to understand. The coordinate transformations are easy in terms of coordinate time, they would be much more difficult in terms of proper time. In fact, with your alternate definition of [itex]\omega = d\theta/d\tau[/itex], what exactly are the transformations between your coordinates and an inertial coordinate system? And, what is the metric in your coordinate system?
Btw, the advantage of my approach is that it applies for any arbitrary worldline in any arbitrary coordinate system and will always give the correct proper acceleration. A derivation based on potentials only works for static spacetimes where potentials can be defined, and I am not sure that it works in any coordinates where the particle is not stationary. I don't see any advantage to it when the general approach is so straightforward.
The advantage is that [itex]\omega = d\theta/d\tau[/itex] is what the experimenter measures directly.
As to the potentials, they can always be calculated, see Moller, see Gron.
  • #177
30,152
6,616
I am still very curious about the coordinate transform and metric that you are using. Please post them at your earliest convenience.
AFAIK a scalar potential can only be calculated in a static spacetime. What is the general formula for calculating a potential? The one in Gron 5.20 was certainly not general.
  • #178
1,568
Both were posted in this thread.
That was also posted.
But it gives the correct answer to the problem. An answer that you still have not admitted that it is correct.
  • #179
30,152
6,616
As far as I could tell, the only metric you posted in this thread was Gron's metric.
Gron's line element (5.5) :
[tex]ds^2=(1-\frac{r^2\omega^2}{c^2})(cdt)^2+2r^2\omega dt d\theta+(r d \theta)^2+z^2[/tex]
But you are not using Gron's [itex]\omega[/itex] so you are not using Gron's coordinates nor his metric. I already demonstrated how using Gron's coordinates and metric leads to the expression involving [itex]\gamma[/itex].
You cannot have it both ways, either you are using Gron's coordinates and metric, in which case my formula follows, or your formula is also correct, in which case you are not using Gron's coordinates and metric.
  • #180
3,962
  • #181
30,152
6,616
Those metrics are incomplete, please provide the remaining terms. Especially all of the terms involving [itex]\omega[/itex]. I don't know why you are being so evasive about this.
  • #182
1,568
Here.
You DON'T NEED the remaining terms.
  • #183
1,568
I think Starthaus is talking about the derivation in his blog attachment titled "acceleration in rotating frames". It is incomplete, but I completed it for him in https://www.physicsforums.com/showpost.php?p=2693087&postcount=100"and he said my final solution is correct.
I am not 100% sure it is.
Yes, this is the method that uses coordinate transformations in rotating frames. You did complete the calculations after a lot of prodding and prompting and correcting your calculus errors.
  • #184
30,152
6,616
Here.
The post you linked to has only Gron's metric which you are not using and the "standard" metric which is incomplete.
I find your evasiveness very disturbing. It is not as though it is unreasonable to ask for the metric.
  • #185
1,568
Of course I am using the Gron metric. It is the same as the metric used in Rindler (9.26). If you read this thread rather than jumping in, you would have seen that.
You only need the first term (the coefficient for [tex]dt^2[/tex]) of the "standard" metric, you get the potential through a simple identification.
[tex]-ds^2=\left(1+\frac{2\Phi}{c^2 }\right)^{-1}dr^2+r^2(d \theta^2 +\sin^2 \theta d \phi^2)-c^2 \left(1+\frac{2\Phi}{c^2}\right)dt^2[/tex]
This is your problem, the same exact approach is used in Rindler chapter 11. It can also be used very successfully in deriving the gravitational acceleration of a radial field (much more elegant than the covariant derivative solution)
  • #186
30,152
6,616
Thanks for posting the "standard" metric.
If you are using the Gron metric then your result is wrong. The [itex]\omega[/itex] he uses is [itex]\omega=d\theta/dt[/itex] (see eq 5.2). The only way your result can be right is if you are using a different metric where [itex]\omega=d\theta/d\tau[/itex].
  • #187
1,568
You are welcome.
I am using the metric present in the Gron book, also present in the Rindler book.You need to look at Rindler, chapter 11.
If you use the weak field approximation, you get the result I showed you.
If you use the strong field approximation:
[tex]ds^2=e^{2\Phi/c^2} dt^2-....[/tex]
you get :
[tex]\Phi/c^2=\frac{1}{2}ln(1-\frac{r^2\omega^2}{c^2})[/tex]
[tex]\vec{F}=-grad(\Phi)=\frac{r\omega^2}{1-r^2\omega^2}[/tex]
Now:
[tex]\omega=\frac{d\theta}{dt}=\frac{d\theta}{d\tau}\frac{d\tau}{dt}=\omega_{proper}\sqrt{1-r^2\omega^2}[/tex]
So:
[tex]\vec{F}=r\omega_{proper}^2[/tex]
Same exact result as in chapter 92, expression (97) page 247 in Moller ("The General Theory of Relativity")
  • #188
30,152
6,616
you get :
Now:
So:
OK, your results using the strong field approximation are correct and agree with the covariant derivative approach.
Is this the correct full expression for the strong-field approximation metric:
[tex]-ds^2=\left(e^{\frac{2\Phi}{c^2 }}\right)^{-1}dr^2+r^2(d \theta^2 +\sin^2 \theta d \phi^2)-c^2 \left(e^{\frac{2\Phi}{c^2}}\right)dt^2[/tex]
  • #189
1,568
yes,it is
  • #190
3,962
The result is incorrect, a correct application of covariant derivatives (as shown here) gives the result [tex]a_0=r\omega^2[/tex].
Now:
So:
OK, you have effectively defined proper centripetal acceleration as:
[tex]a_0=r\omega_{proper}^2[/tex]
using your definition:
[tex]\omega=\frac{d\theta}{dt}=\omega_{proper}\sqrt{1-r^2\omega^2}[/tex]
This means in your coordinates, the coordinate acceleration is:
[tex]a=r\omega_{proper}^2(1-r^2\omega^2) = r\omega^2 = a_0 \gamma^{-2} [/tex]
and the fundemental relationship
[tex]a_0 = a\gamma^2[/tex]
between proper and coordinate centripetal acceleration, given by myself in #1 and later by Dalespam and others is correct.
  • #191
1,568
It is not "my" definition, it is the standard definition.
The difference is that you did not derive anything (unless we factor in the stuff that I guided you to derive from the rotating frames transforms). Putting in results by hand doesn't count as "derivation".
Besides, post #3 shows that the naive transformation of force you attempted is wrong.
  • #192
3,962
I never claimed that I derived the equations in #1. I merely stated them and pointed out some relationships between the equations.
The transformation of force that you object to in #3 is the perfectly standard Lorentz transformation of force and unless you are claiming the Lorentz transformations are wrong, there is no need for me to derive them.
You seem to think that angular acceleration might somehow make the transformation of centripetal force different from the transformation of linear transverse force, but if you understood the ramifications of the clock postulate you would know that acceleration has no effect on time dilation or length contraction and we only need to consider the instantaneous tangential velocity of a particle to work out the transformations of an accelerating particle. So all I did was apply the Lorentz transformation (which does not need deriving because it is an accepted standard result) and the clock postulate (which does not need deriving because it is a postulate supported by experimental evidence).
Your main objection seems to be that, even though I get the correct result, the method I used is not complicated enough.
  • #193
1,568
What has been explained to you is that the respective transformation is derived from the Lorentz transforms for translation. As such, it does NOT apply to rotation. Physics is not the process of mindless application of formulas cobbled from the internet.
You applied the inappropriate Lorentz transform. I do not expect you to understand that.
My main objection is that you don't seem to know the domains of application of different formulas. I taught you how to derive the force transformation starting from the correct formulas: the transforms for rotating frames. You can't plug in willy-nilly the Lorentz transforms for translation.
  • #194
3,962
I showed you how the clock hypothesis means that the Lorentz transforms for translation can be applied to rotation. You basically have the same misconception as many beginners to relativity, that think Special Relativity can not be applied to cases involving acceleration. My process of application is not ""mindless". I used logic applied to information from reliable sources and then got a second opinion about the results I obtained from the more knowledgeable members of this forum like Dalespam.
I did not. If I had I would have got the wrong result, but I did not. Everyone but you in this thread says the results I got in #1 are correct. All you have done is changed the definitions to make your results look different. This is like saying the speed of light is 299792.458 km/s and not 299792458 m/s, when in fact both answers are correct but are using different units. You fail to understand that our results are in agreement and they only differ in that my results are obtained much quicker and more directly.
  • #195
1,568
The point is that you shouldn't try to apply the transforms derived for translation to a rotation exercise. This is precisely why special transforms have been derived for the case of rotation.
The type of hacks you keep attempting don't count as correct derivations , even if they produce the correct results by accident.
LOL. You "forgot" the files that I wrote about accelerated motion in SR. You "forgot" the relativistic transforms for rotation that I tried to teach you.
I simply tried to teach you how to use the correct SR equations as they apply to rotation.
  • #196
1,568
there is something wrong with rhs of your two eqautions:
if
[tex]\frac{d}{dt}( m_0 v)=q v x b[/tex]
is true, then by the properties of simultaneous equations, it must follow that:
[tex]\frac{d}{dt}(\gamma m_0 v)= (q v x b) \gamma [/tex]
lol.
Related Threads on Relativistic centripetal force
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
