Homework Help: Relativistic Dynamics problem
  1. Mar 8, 2014 #1
    1. The problem statement, all variables and given/known data A particle of mass m and kinetic energy K strikes and combines with a stationary particle of mass 2m, producing a single composite particle of mass √17 m. Find the value of K
    2. Relevant equations
    E= γmc^2 , p = λmv
    3. The attempt at a solution I have tried many times at this and have used the conservation of energy and conservation of momentum but I seem to get nowhere. The equations are definitely solvable and this seems to just be algebraic manipulation. My question is whether there is any way to simplify these problems as I just cannot get an expression for K without the other variables, this problem keeps cropping up in other questions too!
  3. Mar 8, 2014 #2
    DataGG
    Show us what you've done please.
    EDIT:
    Also, check out this link. You should get used to writing in latex for physics/math.
  4. Mar 8, 2014 #3
    rude man
    Does the composite particle have zero K.E.?
  5. Mar 8, 2014 #4
    Hi Rudy. Not necessarily.
    Chet
  6. Mar 8, 2014 #5
    You should be able to manipulate and combine the momentum balance and the energy balance into a single quadratic equation involving the variable x = K/(mc2). It takes some playing with the math to bring this about. So, as Strange said, show us what you did, and maybe we can give you some hints on manipulating the math.
    Chet
  7. Mar 9, 2014 #6
    rude man
    Hi Chet, right. Hadn't realized.
    I'll leave this one to you, assuming the OP responds. Lately the only responses I get are from other helpers ... bedides, I'd only invoke rest mass again, stirring that controversy up again probably. :grumpy:
    rudy
  8. Mar 9, 2014 #7
    What's wrong with invoking rest mass? That seems to be a large part of what this problem is about.
    Chet
  9. Mar 9, 2014 #8
    rude man
    I learned 'modern physics' in the early '60's when there was a separate symbol for rest mass: m0. Recently it was pointed out to me in these forums that that is no longer in vogue: there is only one mass, m. If at rest it's m, if moving it's γm. So among other casualties it's no longer E = mc2 but γmc2, and p = mv is no longer correct either. I find this change entirely pointless but found out to my distress that I was in the rank minority ... I suppose I made a mountain out of a molehill but still I see no reason to fix what isn't broke.
  10. Mar 9, 2014 #9
    Yes, I see. There used to be rest mass and relativistic mass. Now, for good reason, there's no meaningful quantity called relativistic mass. Rest mass and m are now one and the same.
    Chet
Have something to add?
Draft saved Draft deleted
Loading...
