Relativistic Effects for Copper and Gold
In summary, the colors of copper and gold, compared to other metals like silver, are due to relativistic effects on the valence electrons. This is because the electronic configurations of these metals are similar, but the relativistic effects get stronger for heavier atoms. This is reflected in the d band structures for copper, silver, and gold, with gold showing a breaking of the periodic trend and a change in the relative spatial extents of the d and s orbitals. Relativistic effects also play a role in other properties, such as mercury being a liquid at room temperature. Overall, while relativistic effects may offer a simple explanation for these differences, they are part of a more complex picture.
jeanpinto844
TL;DR Summary
Relativistic effects on the quantum states of electrons in Copper and Gold
Summary: Relativistic effects on the quantum states of electrons in Copper and Gold
Hello. I am a new member.
I have read that the explanation for the colors of copper(red) and gold(yellow) compared to other metals being silver or grey in color is due to relativistic effects on the valence electrons in those metals. Is this explanation enough? Silver is within the same group as Cu and Au but silver has no characteristic color. How are copper and gold affected by relativity and not silver? I have also read that mercury is a liquid also due to relativistic effects. How is Hg affected but not Zinc or Cadmium? One would perhaps expect the metals on the lower half of the periodic table such as Pb or Bi to also be affected by relativity and have certain characteristics that their neighbors do not. Are relativistic effects just a simple answer/explanation to what is a much more complicated answer?
From a chemist's perspective, the electronic configurations for Cu Ag and Au are 4s1 3d10, 5s2 4d10, and 6s2 4f14 5d10, respectively so one would infer that relativistic effects should take place for all three metals considering they have the exact same configurations. The same can be said for Zn, Cd, and Hg which all end in the same configurations.
Relativistic effects get stronger for heavier atoms. Here's a powerpoint with band structures for copper, silver, and gold:
http://lampx.tugraz.at/~hadley/ss1/lectures16/jun9.pdf
As you can see, the d bands for copper kick in at around 2 eV (~620 nm) below the Fermi level, meaning that most incident light is absorbed above 2 eV, leaving mainly reddish light (>620nm) to be reflected. For silver, the d bands come at around 4 eV (~310 nm) below the Fermi level, well into the UV, meaning most visible light is reflected. For gold, if the periodic trend were to hold, you'd expect the d bands to appear at greater than 4 eV below the Fermi level. Instead, you see the d bands pop up at somewhat less than 2 eV (with another important peak in the blue wavelengths), and the band structure is such that yellow light mainly gets reflected. The breaking of the periodic trend occurs notably in gold, changing the relative spatial extents of the d and s orbitals (and therefore changing the excitation energy/density of states). The relativistic effect for silver is less than in gold, and much less (nearly negligible) in copper.
Likes Spinnor and DrClaude
1. What are relativistic effects?
Relativistic effects refer to the changes in physical properties that occur when an object approaches the speed of light. These effects are predicted by Einstein's theory of relativity and have been observed in various experiments.
2. How do relativistic effects impact copper and gold?
Due to their high atomic numbers, copper and gold experience significant relativistic effects. These effects can cause changes in the electronic structure and properties of these metals, such as increased mass and energy levels.
3. What is the significance of relativistic effects in copper and gold?
Understanding and accounting for relativistic effects is crucial in accurately predicting and explaining the behavior of copper and gold in various applications, such as in electronics and catalysis.
4. How are relativistic effects measured in copper and gold?
Relativistic effects in copper and gold can be measured through various techniques, such as X-ray spectroscopy and electron microscopy. These methods allow for the observation and analysis of the changes in electronic structure and properties caused by relativistic effects.
5. Can relativistic effects be manipulated in copper and gold?
While it is not currently possible to directly manipulate relativistic effects in copper and gold, scientists are exploring ways to control and utilize these effects for potential applications in nanotechnology and quantum computing.
  • Other Physics Topics
  • Electromagnetism
