Relativistic Gravity: Is It Weaker or Stronger? | Thought Experiment
In summary, there is a general consensus that a relativistically moving body in frame B will be perceived by a lab frame A as having a greater gravitational pull related to the increase in its “relativistic mass," but it is a complex topic with differing views and a lack of observational evidence.
DiracPool
1,243
516
I know this topic has come up several times throughout the years, but after reviewing a good number of the threads, I’m still not clear as to whether any kind of consensus on the matter has been reached or not, or if there may be new developments in either theory or observation. If you review the threads below, you will see a divergence of views on the matter. Generally, it’s either 1) yes, a relativistically moving body in frame B will be perceived by a lab frame A as having a greater gravitational pull related to the increase in its “relativistic mass,” 2) there is no effect at all, the relativistically moving frame B has the same gravitational pull as it would in the lab frame of A, and 3) it’s too complicated to figure out because only one of the terms in the stress energy tensor relates to “relativistic mass,” the equations are too hard to figure out, and there’s no observational evidence to compare anything against:
https://www.physicsforums.com/threads/does-relativistic-mass-create-gravity.68454/page-2
https://www.physicsforums.com/threads/does-relativistic-mass-induce-gravity.413594/
https://www.physicsforums.com/threads/relativistic-mass-and-gravity.626128/
https://www.physicsforums.com/threads/relativistic-mass-and-gravity.675637/
So, in lieu of observational evidence, most posters in these threads come up with thought experiments to try to gain insight on the manner. I’m going to do the same here with a fresh thought experiment I didn’t see in the other threads and see if anyone can, say, pick it apart some, here goes:Earth has a twin planet named “Bearth,” with exactly the same radius and mass in kgs. One day Bearth comes zooming through the solar system and passes Earth at 0.87c (relative to an x coordinate which lines up parallel to the equators of both planets), giving Bearth a relativistic gamma factor of 2 relative to Earth in the x direction. On the planet Bearth there are two twin sisters, Alice and Beth. Both of these girls are 6 feet tall (being twins, of course).Alice and Beth are playing a game, the game is for both girls to hold their arms straight out, drop a baseball, and see which one hits the ground first. They are not sure whose ball will, because Alice is standing on the north pole of Bearth and Beth is standing on the equator. Low and behold, though, when they try the experiment/game, they find the balls hit the ground at roughly the same time, and the acceleration of each ball is 10 m/s^2.Now, while this going on, Bob on planet Earth is watching Alice and Beth play this game through his powerful telescope and wants to play too. Bob is also 6 feet tall and is standing parallel to Alice on the north pole of the Earth. Looking through his telescope, he sees when Alice and Beth drop their baseballs and then proceeds to drop his own at the exact same instant. What does Bob notice?From what I can tell, Bob notices that, while he sees his ball fall to the ground at time t, he sees Alice’s ball fall to the ground at time 2t due to the time dilation gamma factor of 2 described above. Is this not right? In that case, wouldn’t this appear to Bob as if the force of gravity on planet Bearth is less than that of Earth, rather than greater due some putative “relativistic mass.” As far as Beth is concerned, it would seem as though Bob would witness his and her ball hitting the ground at the same time because, while Beth’s ball takes twice as long to hit the ground, she is only half the size as Bob at 3 feet tall due to her length contraction in the x-direction of movement.So, at least according to this thought experiment, the relativistic velocity of Bearth would seem to have the effect of making gravity appear to be weaker on Bearth than Earth relative to Bob’s perspective. Is this wrong? If so, please explain why and what theoretical and observational work illuminates this issue.
Note: I'm still learning GR. That said, I think this can be handled with just SR.
I think you can analyse this quite simply with just Lorentz transforms. In the frame of Bearth, which I shall assume to symmetric and non-rotating with radius R, one ball starts at (t,x,y,z)=(0,R+h,0,0) and finishes at (T,R,0,0). The other starts at (0,0,R+h,0) and finishes at (T,0,R,0). Lorentz tells us that, in the frame of Earth:
(0,R+h,0,0) → (-γv(R+h)/c2,γ(R+h),0,0)
(T,R,0,0) → (γ(T-vR/c2),γ(R-vT),0,0)
(0,0,R+h,0) → (0,0,R+h,0)
(T,0,R,0) → (γT,-γvT,R,0)
We can then evaluate the coordinate time seen by an observer on Earth:
  • For the ball at the "leading" pole this is γ(T-vR/c2) - -γv(R+h)/c2 = γ(T+vh/c2)
  • For the ball on the "side" pole this is γT - 0 = γT
From this we can see that the gravitational field isn't spherically symmetric anymore, which isn't surprising since Bearth is length-contracted in its direction of motion. I'm not sure what this says about the "strength" though. I'd be inclined to factor out the motion-induced time-dilation, since we'd be able to observe other processes like clocks ticking slow by that factor. In that analysis, the strength perpendicular to the motion is unaffected, perhaps unsurprisingly. However, the field parallel to the motion has changed - the fall time is no longer T, but T+vh/c2. That means that the fall time no longer has the same functional form that it does in Bearth's rest frame. That isn't something you can easily define as "stronger" or "weaker". It's just different.
I'm a little surprised that the Earth-viewed fall time is greater than the Bearth-viewed one. I wonder if someone could check my maths. And, you know, the whole methodology.
As nearly as I can tell, there is a clear consensus (the answer is yes), but it's complicated. I think where you are getting confused is because in some of the posts you have referenced, the emphasis of the discussion is on the fact that calculations of "relativistic mass" (a thoroughly deprecated term by the way) do NOT give the right answer when trying to get a numerical answer to your question. The energy put into the "moving" object causes an increase in speed and thus a concomitant increase in momentum and it is the mathematically complicated relationship between that and the gravitational attraction that causes the confusion. In short, what I am saying is that I think all of the answers are "yes", but some of them are more the more correctly stated "yes, BUT ..." and it is the discussion of the "but" that makes it seem somewhat as though some of the answers are "no".
That's exactly my point, though. We are talking about how Bob sees the gravitational potential on Bearth, not Alice. We can all agree that, since Alice's clock is running slow compared to Bobs, her experience of gravity will be unaffected by her relative motion. Bob, however, will see Alice's ball fall at a slower rate of acceleration than his ball falls at, and will thus conclude that the force of gravity is therefore weaker on Bearth. At least weaker when measured from the poles of Bearth. You could then say, well this is an optical illusion caused by the Lorentz factor, and that if you matched up the fall rate of Alice's ball with the rate her clock ticks, then everything comes out even, etc. And I'd say you are absolutely right. But then you could say the same thing about the twin paradox. Something different is happening there because, when the traveling twin shows up back on Earth, she is physically younger than her brother. So things don't actually add up as you might think they should.
In the same way, we can imagine an experiment where Alice, Beth, and Bob repeat the ball dropping experiment 1000 times, all at the exact same rate relative to their rest frame, and then compare their results when say, the planet Bearth makes a turn around sometime later and arrives back near the Earth in a twin paradox-type scenario. Here we are going to find that, while in that time Bob did indeed perform the ball drop experiment 1000 times, Alice was only able to perform it, say 500 times. Why? Because that ball was just falling so darn slowly, she couldn't make it to 1000 drops. Why was it falling slowly? Because the gravitational potential on Bearth was weaker during the trip, at least from Bob's perspective. Alice didn't notice the difference, but Bob did. And it's not an optical illusion because there is a measurable effect. Bob was counting on Alice to perform that experiment 1000 times for their class project and she only accomplished half her assignment. The only excuse she and her lab partner Bob are going to have when they show up for class on Monday is that they couldn't complete the experiment in the time allotted because the gravity on Alice's planet was half that on Bob's planet.
Again, you could say that Alice was only able to perform the experiment 500 times not because the gravity was weaker on Bearth, but only because her clock was running more slowly. And my reply would be to say, "what's the difference?" You can focus on whatever measured variable you want and use it to explain an anomaly in another. For example, say there were no clocks on the planet Bearth and all Bob had to go on were his visual observations. All he could say about the situation is that Alice's ball fell at a slower rate than his and, thus, it appears that the gravitational potential on Bearth is less than it is on Earth.
Where am I off here?
Since all experiments are slowed down, not just the ones involving gravity, its simpler to describe it as time slowing down. Trying to describe the same effect by tweaking of all possible forces would be more complicated, and conflict with static force measurements.
I'm aware of that which is why I put it in quotes. But the reason I used it is because I think the topic of this thread is a good way to analyze or expose why it is a deprecated term. On it's face, it would seem as if a "relativistic mass" increase of a body, A, traveling relative to rest body, B, would make it appear to B that A had a greater gravitational potential. This apparently isn't as simple as taking the relativistically corrected mass value and plugging it into Newton's equation. The question is why is this, and what is the actual effect on gravity of a relativistically moving body? Furthermore, I'm not sure how useful it is even to dissociate "relativistic mass" into components of, say, "rest (inertial) mass" plus kinetic energy. Even in this case the added kinetic energy should increase the gravitational potential of the body A relative to B. But is this observed? I don't know, that's what I'm trying to get at here. Are there models of how mass and energy terms are split up in the stress energy tensor to explain how spacetime curvature around relativistically traveling bodies is manifested?
Also, I'm not an astronomer but couldn't they, say, compare binary star systems of similar mass and orbital-radial arrangements but traveling at different velocities relative to each other and the Earth and get some experimental data that way? Again, I'm way out of loop on how these things are measured but just putting it out there.
That's a good point, especially considering that Beth at the equator of Bearth would return to Earth's rest frame having actually completed the experiment 1000 times as in Bob's case. Although, she would have also aged half the time Bob had during her journey. Which sort of complicated the picture again..
You're starting from the assumption that SR+Newtonian Gravity will give you a realistic theory of relativistic gravity. It won't. That's why GR was developed.
DiracPool said:
On its face, it would seem as if a "relativistic mass" increase of a body, A, traveling relative to rest body, B, would make it appear to B that A had a greater gravitational potential.
Why? To the extent that relativistic mass is a useful concept, it applies to the three-acceleration of an object in response to applied forces - and that doesn't have much to do with gravity.
With just SR the balls never hit the ground.
Why do you think this would happen? Wouldn't the number of experiments completed by Beth have to bear the same relationship to the amount she ages as Alice's does?
Peter - you are correct, of course. What I was trying to get at was that it is possible to take a couple of points on the path of each ball without worrying about the details of why the balls are following that path. Then we can just Lorentz-transform those events and end up being able to say something about the behaviour of the force (or "force" in this case) wthout invoking the full machinery of GR.
I think that argument is ok.
I don't think that will tell you anything about gravity since it is not a force in relativity. A similar argument could be used to tell you how the EM force transforms, but not gravity.
This won't work because you can only use a Lorentz transform this way in flat spacetime, and if gravity is present spacetime is not flat.
OK - but I thought the whole point of tensors (which the 4-position of the events are) was that they transformed in a straightforward way under a Lorentz boost. I take it that I've been a bit too casual about that. What would (a sketch of) the correct procedure be?
First, "4-positions of events" are not tensors. Nor are differences between two 4-positions, i.e., displacements. In flat spacetime, you can get away with thinking of displacements as 4-vectors, but this doesn't work in curved spacetime, so it's best not to get into the habit.
Second, the point of tensors is that they transform in a straightforward way under general coordinate transformations. This is a much wider class of transformations than Lorentz transformations--which, as I said, don't even work in curved spacetime anyway.
First, you need correct expressions for the worldlines of the two falling objects; you assumed they were straight lines in the Bearth-centered coordinates, but they're not.
Second, you need a correct expression for the metric in the Bearth-centered coordinates; it's not the Minkowski metric.
Third, you need a correct expression for the coordinate transformation from Bearth-centered coordinates to Earth-centered coordinates; it's not a Lorentz transformation.
D'oh. No meaningful concept of "adding two positions together" means positions do not form a vector space. Although you can get away with it in flat space by using vectors from the origin interchangeably with coordinates, since there's a trivial relationship.
Ah - Lorentz transforms are equivalent to switching from coordinates derived from one set of rigid rods with Einstein-synchronised clocks and another set in relative inertial motion. And you can't build such a system in a curved space-time. I'm sure there's a differential geometry way of explaining that...
PeterDonis said:
First, you need correct expressions for the worldlines of the two falling objects; you assumed they were straight es in the Bearth-centered coordinates, but they're not.
I need to solve the geodesic equation in a Schwarzschild metric (I noted earlier that I assumed Bearth was not spinning) subject to the initial condition that the particles are at rest far, far above the event horizon. Right?
I have no idea how to do this. More reading needed, obviously.
That is also the part that I don't know. I am not aware of a standard metric for a moving spherical mass.
Right.
There's a solution called the Aichelburg-Sexl ultraboost that covers this general type of situation:
http://en.wikipedia.org/wiki/Aichelburg–Sexl_ultraboost
However, I don't know the transformation between this solution and the ordinary Schwarzschild metric.
AFAIK, there isn't such a transformation. The Aichelburg Sexl metric is a pp wave spacetime, meaning that it is massless. There is no event horizon.
My $.08 on the concept of forces in general relativity
1) Non gravitational forces are well defined, for instance we can find the force on a charged test particle by comparing it to a reference uncharged test particle. This gives rise to tensor quantities like the Faraday tensor.
2) If you look up "forces" in a GR book, you'll usually not find much under that heading
3) If you look up "Christoffel symbols in a GR book, you'll find lots of stuff under that heading.
4) A subset of the Christoffel symbols can be related to "fictitious forces" in a purely Newtonian context. So if you are in an accelerating elevator accelerating in the z direction, the Christoffel symbols of your connection due to your acceleration (fi.e ##\Gamma^z{}_{tt}##) appear as "fictitious forces" in a Newtonian context.
5) The idea that we can use the fictitious forces in accelerating elevator as some sort of model for "gravity" has a long history in the development of the equivalence principle in particular and GR in general. This suggests that we look for a relationship between the Christoffel symbols and the idea of "gravitational forces".
6) Unfortunately, due to point 2), we don't find a lot in the textbooks on this topic. So perhaps we are invited to draw our own conclusions. But we'll have to be careful when talking about them if there isn't any published consensus view to refer to. Perhaps there is some definitive reference - if someone wishes to quote one, it'd be interesting reading.
7) Christoffel symbols are more than "just" forces - but so is gravity. For instance, we have "gravitational time dilation". This is not a characteristic of any other sort of "force" other than gravity, but is definitely associated with gravity. But Gravitational time dilation is also a Christoffel symbol.
8) So we, or at least I, am led to the conclusion that Christoffel symbols are the replacement for "gravitational forces" in GR. They are, of course, not tensors. How do we explain the fact that forces in Newtonian mechanics do transform as tensors? I would suggest that the point is that while Christoffel symbols are not guaranteed to transform like tensors, under certain specialized limited sorts of coordinate transformations, they can - it's not prohibited, it's just not guaranteed under general transofmations.
If we want to replace forces with Christoffel symbols we still have an issue, because there are too many of the later.. But the extra Christoffel symbols (like gravitational time dilation) do have some physical significance.
So - we (or at least I) can regard the Christoffel symbols as some sort of "superset" of forces - forces + more. And in the context (for instance) determining the equations of motion, we just instead talk about using the Christoffel symbols in the geodesic equation and we note that the equations are formally very similar to the differetial euations we used to get when we had 'forces" in Newtonian theory.
So my end conclusion is - don't worry so much about forces in GR, instead try to understand their more-or-less replacement, Christoffel symbols.
Are you sure? There's an ##m## parameter in the metric. According to the Wikipedia page, this metric can be viewed as the limit of a sequence of pp wave solutions, but I don't think that necessarily means it itself is a pp-wave solution.
That said, the presence of the delta function ##\delta ( u )## in the metric does make me skeptical that there is a transformation to the Schwarzschild metric. I need to look at it in more detail to see how the geodesics look.
No I am definitely not sure. This is way on the edge of my knowledge. However, I don't think that the parameter m in the ultraboost is the same as the parameter m in Schwarzschild. Since it has no event horizon I don't think that it is a Schwarzschild spacetime in different coordinates.
I could definitely be wrong though.
My logic there was that, since Beth was at the equator and thus moving parallel to the x-direction, she would be length contracted and therefore only 3 feet tall, rather than Alice who would still be 6 feet tall on the north pole. Assuming then that the gravitational potential globally remained constant, then I reasoned that Beth's ball would take roughly half the time to hit the ground once she dropped it compared to Alice since it only had to fall half the distance (I say roughly of course because the balls are not falling with constant velocity but rather are accelerating). That may be a naive assumption, I don't know, but that's what I'm trying to explore here.
Now that I think of it, though, the entire planet Bearth would be length contracted in the x-direction (about the equator), so that may also affect the equatorial gravity due to the reduced radius horizontally. Does any sense ring to this argument? I know it is a calculus coming strictly from SR, not GR, but I guess my question would be is there any Lorentzian contribution to the scenario in the initial post even roughly as I have outlined?
That can't affect how many runs of the experiment Beth makes relative to Alice. In Bearth's rest frame, Alice and Beth both make the same number of runs; that means they must also make the same number of runs in any other frame. If Beth is length contracted in the frame in which Bearth is moving, then something else about her must also change in that frame, compared to Alice, in order to keep the number of runs she makes the same.
This aspect of the scenario can actually be captured in a simpler scenario set in flat spacetime (so all the issues about spacetime being curved and Lorentz transforms not being valid don't arise). Consider a pair of light clocks: each clock is two mirrors with a light beam bouncing back and forth between them. Both clocks are at rest relative to each other, but they are oriented at right angles to each other, so one clock's light beam bounces back and forth in the ##x## direction, while the other's bounces back and forth in the ##y## direction. The clocks are synchronized so that they tick at the same rate, meaning that, in their mutual rest frame, the events of the light beams striking each mirror are simultaneous. To make this perfectly clear, suppose that the "A" mirrors of the two light clocks (each clock has an "A" mirror and a "B" mirror, the "A" mirror is the one the clock's light beam is striking at clock time ##t = 0##) are spatially co-located, so that the events of each clock's light beam striking its "A" mirror are the same event.
Now transform to a frame in which both clocks are moving at 0.87c in the ##x## direction. The clock that is oriented in the ##x## direction is length contracted by a factor of 2, while the clock oriented in the ##y## direction is not. Yet the clocks stay synchronized; they have to, because the events of the light beams striking the "A" mirror of their respective clocks are the same event, and that must be true in every frame. So something else must change in the moving frame to compensate for the length contraction of one clock and keep them synchronized. Think about what that something else might be.
I think the short answer is "no", because, as was commented earlier, you can't model gravity as SR plus a "force field".
Thanks for all the help. As I'm clearly earlier in the "making understanding errors" phase of learning GR than I thought, I think I might leave finding the appropriate co-ordinate transform for a later date.
The Wikipedia page cites the original Aichelburg & Sexl article as "On the gravitational field of a massless particle", which sounds fairly definite about whether it is massless. Although given the last paragraph of the page, I'm not sure the editor was completely comfortable with the material:
Wikipedia said:
This resolves the following paradox: The moving particle will "think" that the stationary object
(let's use a planet) has a huge mass, because in the particle's point of view the planet is moving at an ultra relativistic speed. What if the particle moves fast enough so that the planet
becomes a black hole, and the particle gets inside the event horizon? Why does it fly right past (like a photon) and not get trapped?
It hasn't been edited since April 2013.
My impression is that the consensus view on PF recommends the same paper I do, which is "Measuring the active gravitational mass of a moving object", by Olson and Guarino, 1985. Which you can find a lot of threads on if you look. You can definitely find the abstract online which is good, the full paper is even better, you will probably able to find the full paper with google scholar (however, the site one finds this way doesn't inspire a whole lot of confidence to the wary reader.)
This paper sidesteps both the thorny issue of "forces", and "curved space-time" and instead focuses on something that's both easy to measure, easy to communicate without specialized knowledge, and relevant to the problem. This is the velocity change induced in a field of test particles "at rest" after a relativistic flyby. While you'll need GR (of course) to compute this, the good news is that underlying space-time both "before" and "after" the flyby can be considered to be flat, which simplifies the interpretation of the results enormously at the relatively small cost of only providing a rough measure of "average force".
I'll quote the conclusion right from the abstract:
If a heavy object with rest mass M moves past you with a velocity comparable to the speed of light, you will be attracted gravitationally towards its path as though it had an increased mass. If the relativistic increase in active gravitational mass is measured by the transverse (and longitudinal) velocities which such a moving mass induces in test particles initially at rest near its path, then we find, with this definition, that Mrel=gamma(1+beta2)M. Therefore, in the ultrarelativistic limit, the active gravitational mass of a moving body, measured in this way, is not gamma M but is approximately 2 gammaM.
Now the term "active gravitational mass" sounds as if it has some profound significance, but I'm not aware of it actually being used much. In spite of a rather grand-sounding name, it's really very specific to the above method of measurement. The main advantages of this scheme of measurement are pedagogical advantages in talking to a non-expert audience - it's easy to compute, measure, and describe, so that expert knowledge is not needed to interpret or communicate the results. The full paper makes no claim for any profound significance for this defintion of "mass" and additionally introduces the names of some of the sorts of masses that are actually used in the literature by experts. These expert defiitions, however, tend to be hard to communicate to a non-expert audience.
The main conclusion one can easily draw from this paper is that the multiplicative factor of two clearly shoots down any of the ideas that "relativistic mass", or "invariant mass" causes gravity according to usual Newtonian formula. This idea is just plain wrong. So if you have this idea, please drop it.
It's perhaps unfortunate that fully understanding the actual source of gravity, the stresss-energy tensor, requires one to understand tensors, but I'm not aware of any way to fully appreciate the nature of the stress-energy tensor without understanding tensors first. One can get a rather vague idea of what the tensor expressions mean by saying that "energy, momentum, and pressure all cause gravity" without giving more detail.
Assuming you mean proper radius and rest mass, it's quite easy to say that the velocity of Bearth realtive to Earth makes no difference for someone living on the planet. The long thought experiment section on applying the Lorentz transform is both somewhat misguided and unneeded. All you really need is the fact that there is no way to measure one's absolute velocity to realize that the experience of Earth and Bearth will be the same, except for effects caused by lunar and solar tides. That's the uneeded part, the misguided part follows from trying to apply Lorentz transforms in non-flat space-time.
If you want to know the gravitational effects of the passage of Earth through the solar system on some test particles at rest relative to the sun and compare it to the effects of the passage of Bearth, you can use the Olson-Guarino paper to do that (as long as you can ignore solar gravity, that is, so you can disregard the curvature of space-time due to solar graity), and find the gravitational effects due to Bearth's passing on the test particle's velocity field are about 3.5x as big as the effects from Earth's passing.
If you are interested in coordinates that someone might use on Bearth, I would point out that near the planet, one logical choice would be Fermi-Normal coordinates. Actually computing them and extending them through the rest of the solar system though is difficult, I'm not aware of any published paper that does this for the exterior Schwarzschild metric (there are some that do it for the interior metric but this isn't what's needed). I'm pretty sure from my own calculations that you'll wind up with a series solution rather than a closed form one. But there isn't any huge conceptual difficulty (except for the difficulty of describing Fermi normal coordinates to a non-expert audience, and also explaining that these Fermi-normal coordinates won't cover all of space-time), The rest of difficulties are just a matter of calculational difficulty and the lack of ways to check one's work.
[add]Another logical choice might be to use harmonic coordinates, these are probably going to be much more calculationaly friendly than Fermi-Normal coordinates. I'm not super familiar with them, my understanding is you impose the de Donder gauge condition , and that when your goal is to get an approximate metric to some post-Newtonian order (which is how we handle GR in practice in our solar system) this makes your life a whole lot easier.
Hi,
I think to perceive several misunderstandings; it may be useful to first clear those up.
1. According to classical mechanics as well as relativity, the acceleration of a test particle in a gravitational field (such as a ball relative to a planet) is independent of the amount of mass of the test particle (and therefore also independent of the amount of energy), as long as its energy is relatively very small. Thus, while IMHO your paragraph "from what I can tell" gives a correct prediction about time dilation, the thereupon following argument is faulty.
And note that while its gravitational acceleration is independent of its mass, the force with which the particle pushes on the ground is not independent of its mass.
2. There seems to be a mix-up of two very different cases:
a. A system (such as a ball falling towards a planet) as predicted with GR instead of classical mechanics. If the ball is moving at high speed, the prediction of its trajectory as function of time will differ from the classical prediction.
b. An independent system (such as a ball falling towards a planet) as observed with a reference system that is moving relative to it. Here you can use a Lorentz transformation to map from the results found under (a) to that other system.
Did I correctly identify the misunderstandings?
As I said before, you can't do this unless spacetime is flat, and if gravity is present, spacetime is not flat. Lorentz transformations do not work in curved spacetime (except within local inertial frames, which will not cover the situation being discussed here).
Indeed I implied a comparison between two observations from "flat spacetime". I did not carefully read the intended setup sketch; sorry for that!
Note: this does not affect my analysis of the mix-ups.
1. Is relativistic gravity weaker or stronger than classical gravity?
Relativistic gravity is generally considered to be stronger than classical gravity. This is because in the theory of general relativity, gravity is described as the curvature of spacetime, rather than a force between masses. This means that even objects with no mass, such as light, can be affected by gravity.
2. How does the strength of relativistic gravity change with distance?
The strength of relativistic gravity does not change with distance, unlike classical gravity. In classical gravity, the force between two masses decreases as the distance between them increases. However, in general relativity, the curvature of spacetime is constant regardless of distance.
3. Does relativistic gravity affect the motion of objects differently than classical gravity?
Yes, relativistic gravity affects the motion of objects differently than classical gravity. In classical gravity, the force between two masses causes them to accelerate towards each other. In general relativity, the curvature of spacetime causes objects to follow geodesics, which are the shortest paths through curved space. This can result in objects appearing to accelerate towards each other even when there is no force acting on them.
4. Can relativistic gravity be observed in everyday life?
Yes, relativistic gravity can be observed in everyday life. For example, the Global Positioning System (GPS) relies on satellites orbiting Earth, and the clocks on these satellites run faster than clocks on Earth due to the effects of relativity. Additionally, the bending of starlight around massive objects, such as galaxies, is also a result of relativistic gravity.
5. Are there any ongoing experiments or research related to relativistic gravity?
Yes, there are ongoing experiments and research related to relativistic gravity. Some current areas of research include testing the predictions of general relativity, such as the existence of black holes and gravitational waves, and attempting to reconcile general relativity with quantum mechanics. Additionally, there are ongoing efforts to develop a theory of quantum gravity, which would combine the principles of general relativity and quantum mechanics.
