Homework Help: Relativistic Moment F = dp/dt
  1. Sep 13, 2007 #1
    Newton's second law is given by [tex]\vec{F}[/tex]=[tex]\frac{d\vec{p}}{dt}[/tex]. If the force is always parallel to the velocity, show that [tex]\vec{F}[/tex]=[tex]\gamma^{3}m\vec{a}[/tex].
    2. Relevant equations
    [tex]p=\gamma m\vec{v}[/tex]
    [tex]\frac{d\vec{v}}{dt}=\vec{a}[/tex]
    [tex]\gamma = \frac{1}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
    3. The attempt at a solution
    I figure all you need to do would be to find d/dt of p. After a couple tries, I'm still unable to get the result that it provides.
  3. Sep 13, 2007 #2
    Dick
    Yes, that's what you do, and it's straightforward enough. No real tricks. Maybe you could show us an attempt?
  4. Sep 13, 2007 #3
    http://picasaweb.google.com/barry.farmer/Hw/photo?authkey=byWKUltIRn8#5109819187179884178 [Broken]
    Here's a scan of what I did... at the very bottom I was then lost.
  5. Sep 13, 2007 #4
    Dick
    You missed a factor of dv/dt in the first term when you did the chain rule. So factoring out all of the common terms (gamma*m*dv/dt), you only need to show that (v^2/c^2)/(1-v^2/c^2)+1=gamma^2. You are almost there.
  6. Sep 13, 2007 #5
    Thanks for your help... I didn't realize that when I would take the derivative of -v^2/c^2 that it would be (-2v/c^2)(dv/dt). I think that's what you were getting at. I was able to get the answer that way :)
  7. Sep 13, 2007 #6
    Dick
    That's what I was getting at.
Loading...
