• Support PF! Buy your school textbooks, materials and every day products Here!
Relativistic momentum
  • Thread starter abanana
A particle with mass m has speed 0.802c relative to inertial frame S. The particle collides with an identical particle at rest relative to frame S. Relative to S and in terms of c, what is the speed of a frame S' in which the total momentum of these particles is zero? This frame is called the centre of momentum frame.
If particle 2 is at rest in the S frame, then in the S' frame particle 2 must have the same velocity as the S' frame relative to the S frame, but I'm not sure how to apply this.
Answers and Replies
hilbert2
Insights Author
398
Do you know how to form the four-momentum vector for a massive particle in one spatial dimension, and how to write Lorentz transformations as matrices? In this case the vector has effectively only two components and the transformations are 2x2 matrices. You will find help here: http://hyperphysics.phy-astr.gsu.edu/hbase/Relativ/vec4.html
You just have to form an equation for the value of ##\gamma## in the Lorentz transformation that makes the momenta equal in magnitude but opposite in sign.
PeroK
Insights Author
4,506
Do you know how to transform velocities from one frame to another?
@PeroK are you referring to using the equation
v = (u + v')/(1 + uv'/c2)
PeroK
Insights Author
4,506
Yes, you can use that equation. I assume you haven't covered energy-momentum transformations yet? If not, then the above formula is the way to go.
Related Threads for: Relativistic momentum
  • Last Post
  • Last Post
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
