kartikwat
- 49
Whay is it that when we release air from our mouth when it is little open then the cold air is released but when we release air from large open mouth hot air is released.
The thinner faster stream pulls more cold air from surroundings with it.kartikwat said:Whay is it that when we release air from our mouth when it is little open then the cold air is released but when we release air from large open mouth hot air is released.
adjacent said:I can release hot air even when it is opened very little. I think you meant opened little and blowing fast.
klimatos said:I think that you will find that the air coming from your mouth has the same temperature as it had in your mouth regardless of the speed of the stream. The difference is in the effect on a damp surface. The amount of evaporative cooling that takes place on that surface is in direct proportion to the square of the wind velocity
A.T. said:because more cool air is pulled with the stream.
In this case it's not about being colder, but about having less humidity. You breath has 100% relative humidity, so it cannot evaporate the sweat from your finger, no matter how fast you blow. To feel cold the stream must pull with it some less humid air from the surroundings.klimatos said:It's 105°F (about 41°C) here right now. Where's the cool air coming from?
The purpose of releasing air from the mouth is to exhale carbon dioxide from the lungs and to regulate the pressure in the respiratory system.
To release air from the mouth, simply open your mouth and exhale slowly. You can also use techniques such as pursed lip breathing or diaphragmatic breathing to release air more efficiently.
No, releasing air from the mouth is not the same as burping. Burping is a reflex caused by excess air in the stomach, while releasing air from the mouth is a conscious act to regulate breathing.
Yes, releasing air from the mouth can help with relaxation. It can help release tension in the body and calm the mind, especially when combined with deep breathing techniques.
Yes, there are several health benefits to regularly releasing air from the mouth. It can improve lung function, help with stress and anxiety, and promote relaxation. It can also be beneficial for people with respiratory conditions such as asthma or COPD.
