What is the remainder when polynomial f(x) is divided by x^3-x?
In summary: I ask because answers C and D are the same, just with the constant flipped from -1 to 1. If it's not a typo, then clearly, they can't both be right, so you could eliminate one of them. The same thing with C and D goes for E and B.
terryds
392
[/B]
Polynomial f(x) is divisible by ##x^2-1##. If f(x) is divided by ##x^3-x##, then the remainder is...
A. ##(x^2-x)f(-1)##
B. ##(x-x^2)f(-1)##
C. ##(x^2-1)f(0)##
D. ##(1-x^2)f(0)##
E. ##(x^2+x)f(1)##
Remainder theorem
[/B]
f(x) is divisible by ##x^2-1## which means
##f(x) = (x^2-1) H(x)+0 \\
f(x) = (x+1)(x-1) H(x) + 0 \\
f(1) = 0 \\
f(-1) = 0##
f(x) is divided by ##x^3-x## which means
##f(x) = (x^3-x) H(x) + (px+q) \\
f(x) = x (x^2-1) H(x) + px + q \\
f(x) = x(x+1)(x-1) H(x)+ px + q \\
f(1) = p + q = 0 \\
f(-1) = -p+q = 0 \\
f(0) = q##
And, I got p = 0, and q = 0 which means no remainder for the division.
But, the options is very confusing.
Please help
terryds said:
[/B]
A. ##(x^2-x)f(-1)##
B. ##(x-x^2)f(-1)##
C. ##(x^2-1)f(0)##
D. ##(1-x^2)f(0)##
E. ##(x^2+x)f(1)##
Remainder theorem
[/B]
f(1) = 0 \\
f(-1) = 0##
Since it is given that f(x) is divisible by ##x^2 - 1##, then you can say that ##f(x) = (x^2 - 1)H(x)## for some polynomial H. You don't need to include the "+ 0".
f(1) = p + q = 0 \\
f(-1) = -p+q = 0 \\
f(0) = q##
No.
From the earlier work, you have that ##f(x) = (x^2 - 1)H(x)##, so you wouldn't have the equation you have above with ##x^3 - x## in it. Besides this, it can't be true that ##f(x) = (x^2 - 1)H(x)## AND ##f(x) = (x^3-x) H(x)## plus some other terms.
Going back to the first equation I wrote, ##f(x) = (x^2 - 1)H(x)##, if f(x) is divided by ##x^3 - x##, which is equal to ##x(x^2 - 1)##, then everything boils down to whether H(x) is divisible by x or not. Note that saying "if f(x) is divided by ##x^3 - x##", that's not the same as saying "f(x) is divisible by ##x^3 - x##.
Investigate these two cases:
1. If H(x) is divisible by x, what can you say about the terms that make up H(x)? Remember, f(x) is a polynomial, so H(x) must also be a polynomial.
2. If H(x) is not divisible by x, what can you say about the terms that make up H(x)?
Please help
No.
I put it in wrong way...
I mean...
f(1) = 0 \\
f(-1) = 0##
##f(x) = (x^3-x) T(x) + (px+q) \\
f(x) = x (x^2-1) T(x) + px + q \\
f(x) = x(x+1)(x-1) T(x)+ px + q \\
f(1) = p + q = 0 \\
f(-1) = -p+q = 0 \\
f(0) = q##
I know I shouldn't have put H(x) in both equations.. So, I make it different now... H(x) for division by ##x^2 - 1## and T(x) for division by ##x^3-x##..
And I know that it is stated that f(x) is divided by ##x^3-x##.
But, by plugging x=0, x=1, and x=-1, the term 'x(x+1)(x-1) T(x)' will cancel out, and I got two equations relating p and q. And, I found out that p and q are zero.
1. If H(x) is divisible by x, it means that there are no constant in H(x).
2. If H(x) is not divisible by x, it means that there is a constant in H(x).
I mean...
f(1) = 0 \\
f(-1) = 0##
Your LaTeX is a little screwy because you omitted a \\ above
The first line above should really be two lines, like so
##f(x) = (x^2-1) H(x) \\
Again, there's no point in adding the 0 term in the last line. It's not wrong, but it's not needed.
I'm not sure that writing ##f(x) = (x^3-x) T(x) + (px+q)## is helpful. To my way of thinking, this is more helpful: ##f(x) = (x^2-1) H(x)##. If f(x) is divided by ##x^3 - x##, what you get on the right is ##\frac{H(x)}{x}##. This is the reasoning behind my hint with the two cases. If H(x) is divisible by x, there is no constant term, so f(x) would be divisible by ##x^3 - x##, hence the remainder is zero.
As you have already said, (and related to the fact that ##f(x) = (x^2-1) H(x)##), clearly, f(1) = f(-1) = 0. That would tend to eliminate answers A, B, and E.
terryds said:
##f(x) = (x^3-x) T(x) + (px+q) ##
I agree with @Mark44 that writing f(x) in this form is not really helpful.
x3-x=x(x2-1).
f(x)=(x2-1)H(x) and H(x) is also a polynomial, that you have to divide by x when you divide the original function by x3-x. You can write H(x)=xQ(x) + q. So the original function is f(x)= (x2-1)(xQ(x) + q ) What is the remainder if you divide it by (x2-1)x?
f(x) = (x+1)(x-1) H(x) + 0 \\##
Again, there's no point in adding the 0 term in the last line. It's not wrong, but it's not needed.I'm not sure that writing ##f(x) = (x^3-x) T(x) + (px+q)## is helpful. To my way of thinking, this is more helpful: ##f(x) = (x^2-1) H(x)##. If f(x) is divided by ##x^3 - x##, what you get on the right is ##\frac{H(x)}{x}##. This is the reasoning behind my hint with the two cases. If H(x) is divisible by x, there is no constant term, so f(x) would be divisible by ##x^3 - x##, hence the remainder is zero.
Alright, so this is it
##f(x) = x(x^2-1) \frac{H(x)}{x}##
But, I don't know if H(x) is divisible or not since f(x) is unknown.
x3-x=x(x2-1).
##f(x) = (x^2-1)H(x) \\
H(x) = f(x)/(x^2-1) \\##
Since f(x) is unknown, I can't find out what H(x) is.
So, I don't know if H(x) is divisible by x, or not.
So, it will be
f(x)= (x)(x^2-1)(Q(x) + q/x ) \\
f(x) = x(x^2-1)Q(x) + (x^2-1)q##
But, what is q? I can't find out what q is
terryds said:
f(x)= (x)(x^2-1)(Q(x) + q/x ) ##But, what is q? I can't find out what q is
It will be
f(x)= (x^2-1)(xQ(x) + q ) ##
What is the remainder in terms of q? What do you get if x=0?
ehild said:
It will be
f(0) = -q
So, q = -f(0)
Alright, so, the remainder is D. ##(1-x^2)f(0)##, right??
yes.
Likes terryds
But H(x) either is or is not divisible by x. That was my reason for suggesting that you investigate the two cases back in post #2.
Likes terryds
1. What is the Remainder Theorem for Polynomials?
The Remainder Theorem for Polynomials states that when a polynomial f(x) is divided by x-a, the remainder is equal to f(a). In other words, the remainder when dividing a polynomial by x-a is the value of the polynomial when x is replaced by a.
2. How is the Remainder Theorem useful?
The Remainder Theorem is useful for finding the remainder when dividing a polynomial by a certain value, without having to actually perform the division. It can also be used to evaluate polynomials at specific values, which can be helpful in solving equations or graphing functions.
3. Can the Remainder Theorem be applied to all polynomials?
Yes, the Remainder Theorem can be applied to all polynomials, including those with multiple terms and exponents. However, it only applies when dividing by linear factors such as x-a or x+b. It cannot be used when dividing by quadratic or higher degree factors.
4. How is the Remainder Theorem related to the Factor Theorem?
The Remainder Theorem and the Factor Theorem are closely related. The Factor Theorem states that if a polynomial f(x) has a factor x-a, then f(a) = 0. This is essentially a restatement of the Remainder Theorem, where the remainder is equal to 0 when dividing by x-a.
5. Are there any limitations to the Remainder Theorem?
One limitation of the Remainder Theorem is that it only applies when dividing by linear factors. It also cannot be used to find the quotient when dividing polynomials, as it only gives the remainder. Additionally, the Remainder Theorem only applies to polynomials with real coefficients.
