Is this summation limit a valid representation of e^x?
  • Thread starter quinn
In summary, the conversation discusses the validity of taking the summation limit of an equation involving x^n/n! and whether it has any theoretical problems. It is determined that the equation is sound and can be defined as the Taylor series for e^x. A small modification is suggested, involving X^(n+0.5) and (n+0.5)! (or GAMMA(n+3/2)) which changes the behavior of the sum at small n but remains the same at infinity.
quinn
44
Is it valid to take this summation limit:
sum (from n=0 to n=infinity) = (x^n)/ n(!) --(goes to)--> e^x
Or is there a thoerical problem with this? I am fairly certain that this is sound, but I want to get some opinions of possible downfalls of this logic...
Apart from a couple little problems, that's just the taylor series for e^x, which converges everywhere. You might even define e^x by that series. (the problems are that equals sign after the "sum (...)" which shouldn't be there and the "goes to" should just be an equal sign, since there isn't any limit being taken. Alternatively, if you truncate the series at some N, then the partial sums go to e^x as N goes to infinity.)
[tex]\sum_{n=0}^{\infty}\frac{x^n}{n!}=e^x[/tex]
also...
Sorry about the typo,...
now:
SUM (n = 0, n goes to infinity) X(n + 0.5)/(n +0.5)! --> goes to ?
What does this small modifcation do to the sum?
At infinity the sum is the same as before, but at small n the behaviour is different...
Do you mean X^(n + 0.5)?
What do you mean by (n+0.5)! ? If you're thinking of the gamma function, write out (n+0.5)! in terms of ordinary factorials.
so many typos I make
Again I am sorry for the typos
SUM(n=0 to infinity) [X^(n+1/2)]/(n+1/2)! --> goes to?
(n+1/2)! can be written as GAMMA(n+3/2)
The above sum is very similar to the talyor series for e^x, but not quite the same
1. What is the difference between Remanian and continuous?
Remanian refers to a type of discontinuous function that has a jump or "break" in its graph, while continuous functions do not have any breaks or interruptions in their graph.
2. How can I convert a Remanian function to a continuous one?
To convert a Remanian function to a continuous one, you can use a mathematical technique called "removing the discontinuity" or "taking the limit" at the point of the jump. This involves finding the value of the function at the point of the jump and then using this value to redefine the function at that point so that it is continuous.
3. Can all Remanian functions be converted to continuous ones?
No, not all Remanian functions can be converted to continuous ones. Some Remanian functions, such as those with infinite jumps or those with an infinite number of jumps, cannot be made continuous. This is because the jumps are too large or too frequent to be "smoothed out" by taking the limit.
4. Why is it important to convert Remanian functions to continuous ones?
In many areas of mathematics and science, it is important to work with functions that are continuous. This is because continuous functions have properties that make them easier to study and analyze, and they also have real-life applications in fields such as physics, engineering, and economics. Converting Remanian functions to continuous ones allows us to work with these functions in a more efficient and meaningful way.
5. Are there any real-life examples of Remanian functions?
Yes, there are many real-life examples of Remanian functions. Some common examples include the Heaviside step function, the Dirac delta function, and the floor and ceiling functions. These functions have applications in fields such as signal processing, electrical engineering, and computer science.
  • General Math
  • Calculus
