What is a Removable Discontinuity and How Does it Affect x=2 in g(x) = x?
In summary, the book says that if x is not equal to 2/1, then f(x)=x. If x=2, then f(x)=1. If x is not equal to 2, then f(x) has a removable discontinuity at x=1.
maria curie
the book says that g(x)= x ,if x is not equal to 2 / 1,if x=2
has a removable disc. at x =2.
I couldn't remove it.I guess I didn't understand a removable dic. completely.I have an exam on friday.I need your help:confused:
thanks
f(x)= x if x is not equal to 2
f(x)= 1 if x is equal to 2.
What is the limit of f, as x-> 2? (Remember that the limit depends only on the values of f close to 2, not at 2!)
WHY is f not continuous at x= 2??
What would happen if you changed the value of f(2) to 2?
f(x) is not cont at x=2 because f(2)=1 is not equal to lim x->2f(x)=2.I know what continuity is.I don't know how we change the value of f(2) to 2 to be continuous x=2??
and what are the conditions of the continuous extension ?Can be every funct.that is not continuous become cont.?
a removable discontinuity is just something that we can fix or adjust to get the function continuous. It usually means a function is discontinuous at some point or hole in the graph and all we have to do is plug the hole if you will, or redefine the function at the point in question. The problem you have has removable discontinuity because all we have to do is redefine the function at some point to get continuity.
1/x has an infinite discontinuity at zero and cannot be fixed
A function is continuous at x= a if and only if:
1) f(a) exists
2) [itex]lim_{x\rightarrowa}f(x)[/itex] exits.
3) [itex]lim_{x\rightarrowa}f(x)= f(a)[/itex]
The function as given satisfies the first two of those at x= 2. It is not continuous because the third is not true: [itex]lim_{x\rightarrow2}f(x)= 2[/itex] but f(2)= 1. Redefining f(2)= 2 will make all three true! That "removes the discontinuity". (In fact, the function becomes f(x)= x for all x.)
As long as the limit exists at x= a we could always redefine f(a) to be that limit and "remove the discontinuity". A discontinuity is "not removeable" if the limit does not exist. [itex]f(x)= \frac{1}{x}[/itex] is not continuous at x= 0, as 1800bigk says, and no value for f(0) will make it continuous: it has an "infinite discontinuity" there.
The function: f(x)= x if x<= 1, f(x)= x+ 2 if x> 1, has a "jump" discontinuity at x= 1. The "limit from the left" is 1, the "limit from the right" is 3. Since those are not the same, there is no "limit" at x= 1.
Marie, this problem is a lot simpler than you're making it. What you're looking for is a function f(x) that is similar to g(x), but is more continuous. The rules are that you must have f(x) be the same as g(x) when x is not 2, but you can choose whatever you like for f(2). Now, take my word, the simplest thing for f(x) that comes to your mind is the right answer.
A lot of the time, mathematics is about finding a really complicated way of saying something that is very simple. Don't walk around thinking that this stuff is too complicated, it's not. It's just that it's not being explained to you in simple terms.
Carl
HallsofIvy ,your explanation is very good,thanks a lot
What is a removable discontinuity?
A removable discontinuity, also known as a removable singularity, is a type of discontinuity in a mathematical function where the function is undefined at a certain point, but can be made continuous by redefining the function at that point.
How can you identify a removable discontinuity?
To identify a removable discontinuity, you can graph the function and look for a hole or gap in the graph at a particular point. You can also check the limit of the function at that point – if the limit exists, but is not equal to the value of the function at that point, then it is a removable discontinuity.
What causes a removable discontinuity?
A removable discontinuity is caused by a point in the function's domain where the function is undefined. This can happen when there is a zero in the denominator of a rational function, or when there is a square root of a negative number in a function.
How can you remove a removable discontinuity?
To remove a removable discontinuity, you can redefine the function at the point where the discontinuity occurs. This can be done by simplifying the function or by using a piecewise function to redefine the function at that point.
Why are removable discontinuities important?
Removable discontinuities are important because they allow for functions to be made continuous at points where they were previously undefined. This can help to simplify calculations and make functions more accessible for analysis and application in real-world scenarios.
