- #1
Thomas Lyons
- 9
- 0
Any ideas on how I would remove an Aluminum drop tube from a gasoline or diesel tank? The tube goes thru a 4" steel pipe that extends 3' to 4' above the tank.
The problem is that after years of being in the tank the aluminum has seized to the steel pipe. I am thinking about trying to melt the aluminum or put a rubber plug in and fill it with dry ice or liquid nitrogen and hope it breaks loose.
I've seen a caustic bucket on the rig make an aluminum hard hat disappear in a matter of minutes so I started researching a possible method of using caustic to strip the tube out but I don't know how to clean up the mess or what would happen to the gasoline if the chemical fell down into the tank. (I can't imagine it would be good) but maybe I could melt it suck it out somehow then neutralize it.
I think I could use a rubber plumbers plug down to tank top to hold the chemical and once neutralized and removed or cleaned remove the plug and the bottom of the tube would just fall into the tank. right now we have to take a metal bar and try to cut it away from the steel pipe and just work our way down to tank top and then fight it to get it out.
Any suggestions? At least can someone tell me what happens to the chemical if it hits the gasoline/methanol and how worried do I need to be about the fumes the reaction will create. Thank you for any help>
