Understanding Renormalization: Exploring Mass and Cutoff in Quantum Field Theory
In summary, the conversation discusses the concept of renormalization and its implications on the value of mass. It is noted that the pole mass of a particle is not arbitrary and is distinct from the mass parameter in the Langrangian. Despite the fact that the finite parts of the renormalized mass may be much larger than the original mass parameter, they still have an effect on the physical results. Therefore, it is important to include m_0 in the renormalized mass equation.
Student57
I have a couple of questions regarding renormalization.
1. If it is possible to change mass as long as we do it simultaneously with changing ultraviolet cutoff, that would imply that the value we pick for mass is more or less arbitrary. If so, how come we have exact decimal value of mass of an electron, which doesn't look arbitrary at all?
2. When we write renormalized mass, m=m_0+dm, we have dm >>m_0. If so, why even include m_0 at all, why not throw it out as something negligible?
Thanks!
The propagator has a pole at a definite energy; this is the mass of the physical particle and is not arbitrary. We distinguish this "pole mass" from the mass parameter that appears in the Langrangian, which depending on your renormalization scheme may have a different value from the pole mass.
Just because dm is formally infinite doesn't mean the finite parts don't matter. We carefully arrange for the infinities to cancel in calculations of physical processes. Then changing the finite parts of the parameters changes the finite physical results.
Likes vanhees71
1. What is renormalization?
Renormalization is a mathematical technique used in theoretical physics to deal with infinities that arise in some theories. It involves modifying the parameters of a theory in order to eliminate these infinities and make the theory more accurate at all energy scales.
2. Why is renormalization necessary?
Renormalization is necessary because some theories, such as quantum field theories, produce infinite results when calculated at certain energy scales. These infinities arise due to the limitations of our current understanding of physics, and renormalization helps us to overcome these limitations and make accurate predictions.
3. What are the different types of renormalization?
There are several types of renormalization, including perturbative renormalization, non-perturbative renormalization, and Wilsonian renormalization. Each type has its own specific method and purpose, but they all aim to eliminate infinities and improve the accuracy of a theory.
4. How is renormalization used in practice?
In practice, renormalization involves a series of mathematical calculations and adjustments to the parameters of a theory. These calculations can be quite complex and require advanced mathematical techniques, but they ultimately help us to make accurate predictions about the behavior of physical systems at different energy scales.
5. What are the limitations of renormalization?
Renormalization is a powerful tool in theoretical physics, but it does have some limitations. It cannot be used to fix all problems in a theory, and it may not work for all types of theories. Additionally, renormalization can sometimes lead to ambiguities and inconsistencies, which require further refinement and development of the theory.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
