Replacing the current by the fields in electromagnetism.
  1. Jan 20, 2014 #1
    hello,
    In electromagnetism from the Lagrangian formulation, one can defines a canonical momentum and applying Euler's equation to that momentum gives the lorentz law.
    To get the Lorentz law, one uses a vector identity, only available because it is said the speed V does not 'feel' the differential operator, for example, that equation
    $$ \frac{d\vec P}{dt} + q\frac{\partial\vec A}{\partial t} + q \vec V.\vec\nabla \vec A= -q\vec\nabla \phi + q\vec\nabla (\vec A.\vec V) $$
    becomes
    $$ \frac{d\vec P}{dt} =- q\frac{\partial\vec A}{\partial t} -q\vec\nabla \phi + q\vec\nabla \times (\vec \nabla \times\vec A) $$
    because
    $$ \vec\nabla (\vec A.\vec V)- \vec V.\vec\nabla \vec A= \vec\nabla \times (\vec \nabla \times\vec A) $$
    in that case.
    The problem is, if I replace
    $$ q\vec V = \vec \nabla \times \vec B -\frac{\partial \vec E}{\partial t}$$ from the Maxwell's equation (sorry for the permittivity and permeability let's say = 1) I can perfectly apply a differential operator on that object. So why we should not apply a differential operator on $$ q\vec V$$
Draft saved Draft deleted
