Resistance and ohm's law
  • Thread starter sonrie
sonrie
35
An aluminum bar 3.74 m long has a rectangular cross section 1.11 cm by 5.30 cm.
What is the resistance ?
R = ____ ohms
What is the length of a copper wire 1.53 mm in diameter having the same resistance?
L= ____ m.
Answers and Replies
mikelepore
551
The things you need are:
A formula for finding the resistance when you know the resistivity of a metal and its geometric shape.
A table that lists the resistivity values for aluminum and other metals.
myominthu
please! answer me! i have 1 problem.
A No.10 copper wire will sofly carry up to 30 Amperesof current.If the copper wire is to be replaced by an aluminium wire and the only availiable guages of aluminium wire in stock are Nos; 8,10,12,and 14 which one would be able to carry 30 A safely? Explain how you made your choice and which data you referred to.
sonrie
35
well the formula is R= p L/A, so i plugged in the numbers which were p = 2.82*10^-8, L was 3.74 and the Area is pi r^2 my answer was 9.71 *10^-6, which is incorrect. What did i do wrong? Help!
sonrie
35
For area i did 1.11*5.30= 5.88^2 =.034, then i multiplied by pi =1.08*^2.
Redbelly98
Staff Emeritus
Insights Author
12,145
166
sonrie, your formula Area = pi r^2 looks odd. Do you know what the "r" stands for? What is the area of a rectangle?
p.s. also, watch those units. I am seeing m, cm, and mm all being used, so we need to be careful with that.
sonrie
35
the r stands for the resistance, p is the resistivity, L is the length of the wire and A is the Area.
Redbelly98
Staff Emeritus
Insights Author
12,145
166
r does not mean resistance in the "Area = pi r^2" formula. But that is irrelevant to getting the resistance of the rectangular wire, so let's drop it and try to get back on track.
We have the formula:
R= p L/A
Earlier you gave values for p and L which look good. We just need the correct value for area A.
This statement was wrought with errors. The area of a rectangle is a simple multiplication, and it does not involve pi.
sonrie
35
Area = .5 B*H, which is .5*1.11*5.30 = 2.94 Is that correct ?
So then my final equation should look like
R= 2.82*10^-8 3.74/2.94 = 3.59*10^-7 Is that what you got?
Redbelly98
Staff Emeritus
Insights Author
12,145
166
I'm going to give up now, as it appears you are deliberately doing this wrong in order to engage a response from people.
My apologies if I am mistaken. Good bye.
astrorob
140
Hmm, I don't think you can jump to that conclusion..
Redbelly98
Staff Emeritus
Insights Author
12,145
166
Here is the evidence. These are all things sonrie has claimed in this thread:
1. The area of a rectangular cross section is given by the formula Area = pi r^2
2. In the above formula, the "r" is resistance.
3. 1.11*5.30= 5.88^2 =.034
4. The area of a rectangle is given by 0.5 B H
People can draw their own conclusions, just as I have done.
astrorob
140
I've dealt with people who struggle quite badly with physics and mathematics and you'd be surprised what people come out with.. They just throw formulas that they've heard around until they hit the correct one without understanding the mechanism behind them.
What you may think as unimaginably easy might not be so to someone less gifted.
sonrie
35
So my answer is wrong!
Redbelly98
Staff Emeritus
Insights Author
12,145
166
I'll acknowledge that I am not 100% certain, and will not be "reporting" him. But I am certain enough to not spend more of my time trying to help this person.
He is still welcome to enlist the help of other members if he is in earnest.
Suggested for: Resistance and ohm's law
  • Last Post
  • Last Post
