• Support PF! Buy your school textbooks, materials and every day products Here!
Resistance and Temperature
  • Thread starter porporking
Hi Physicsforum, this is my first post so apology if I make unclear equation. I try to solve this question by pluging t0 as temp. at Valley and t as temp. at Antartitca directly as oppose to setting separate equation. I got different answer than the solution said
While taking photographs in Death Valley on a day
when the temperature is 58.0°C, Bill Hiker finds that
a certain voltage applied to a copper wire produces
a current of 1.00 A. Bill then travels to Antarctica
and applies the same voltage to the same wire. What
current does he register there if the temperature is
-88.0°C? Assume that no change occurs in the wire’s
shape and size.
The answer from solution book is 1.98 A
ρ = [ρ0(1+α(T-T0))]
R = [R0(1+α(T-T0))]
Rantart = [Rvalley(1+α(T-T0))]
V/Iantart = [V/Ivalley(1+α(T-T0))]
V are same so eliminate V on both side,
1/Iantart = [1/Ivalley(1+α(T-T0))]
Iantart = Ivalley/(1+α(T-T0))
substitute
Iantart= 1.00A/(1+(3.9*10^-3)(-88c-58c)) = 2.32 A
Answers and Replies
mjc123
930
434
Over such a wide temperature range, the equation ρ = [ρ0(1+α(T-T0))] is not a good approximation.
Start with the definition α = (1/ρ)dρ/dT and integrate from T0 to T.
gneill
Mentor
20,783
2,759
ρ = [ρ0(1+α(T-T0))]
R = [R0(1+α(T-T0))]
The ##T_o## here is the reference temperature at which the value of ##\alpha## was determined. If you try to use some other temperature here (such as one of your sampled temperatures), then the equation will not describe the same line.
Luckily, the temperature coefficient you've quoted would appear to be the one for 0°C, so that your ##T_o## is actually zero.
Related Threads for: Resistance and Temperature
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
27K
