Solving for Resistance and EMF in a Circuit: A Guide
In summary: It's simple algebra. Distribute I2 on the right side into the parenthesis. That gives you one R term on the left and one R term on the right, with the additional R1*I2 term on the right. Just move the R term from the right side to the left (you do know how to do that, right?), and then finish solving for R all by itself.R*(2.77) = R*(1.81) + (27.39)
BuBbLeS01
602
What is the resistance R? (R1=15.13 Ω, I1=2.77 mA , I2=1.81 mA. Give answer in Ω.)
What is the emf of the battery?
I = E/R
How do I solve this with the batteries EMF?
Write 2 equations with the two unknowns (V and R), then solve for both.
And shrink that picture!
Ok let me see what I can come up with...
How do you shrink it? I did it on tinypic.com
E = -v1 - V2
E = Ir1 + Ir2
R = E/i
With Paint or other figure manipulation/drawing programs, you can choose to "Save As" and specify the resolution.
Are those the right equations? I am not seeing how to solve this?
BuBbLeS01 said:
E = -v1 - V2
E = Ir1 + Ir2
R = E/i
Write one equation for the current and voltage in the middle branch, and one equation for the current and voltage in the right branch.
MIDDLE BRANCH:
R = E/I
RIGHT BRANCH:
R = E/I1 + I2
That doesn't look right??
BuBbLeS01 said:
MIDDLE BRANCH:
R = E/I
RIGHT BRANCH:
R = E/I1 + I2
Why are you not using the names of the resistors in the figure? There are two resistors in the right branch, correct? And current J1 flows in the left branch, and J2 flows in the right branch. Both branches have the same voltage across them, correct?
Take your time and think it out. I need to bail -- you'll get it (or more help may stop by if you have more questions).
MIDDLE BRANCH:
R = E/I1
RIGHT BRANCH:
R + R1= E/I2
Is that right?
Ok so I think I got it...I just set them equal to each other and I get...
I1 * R = (R + R1) * I2
But for some reason I don't know how to solve for R! I can't figure it out...very sad...please help me! I have tried all sorts of things and I am not getting anywhere...
can anyone help me with this part?
Substitute the values of I1, I2 and R1 and solve for R
Thats what I am trying to do but I can't figure out how to get the R by itself on one side since there are 2 of them. I always end up with R/R which is just 1. Its not making sense to me.
Do you already know what the answer is suppose to be? We use to get the solution to some of our problems, but had to show the work in getting to it.
Do you end up with R*(2.77) = R*(1.81) + (27.39) ?
No I don't know what the answer should be
Please try again, and show each of your steps here.
What is resistance?
Resistance is a measure of how difficult it is for electric current to flow through a material. It is measured in ohms (Ω) and is represented by the symbol R.
What is EMF?
EMF stands for electromotive force and it is the force that causes electric current to flow in a circuit. It is measured in volts (V) and is represented by the symbol E.
How do I calculate resistance?
Resistance can be calculated using Ohm's Law, which states that resistance is equal to the voltage (V) divided by the current (I). This can be written as R = V/I. Alternatively, you can also use the formula R = ρl/A, where ρ is the resistivity of the material, l is the length of the material, and A is the cross-sectional area of the material.
How do I calculate EMF?
EMF can be calculated using the formula E = I*R, where I is the current flowing through the circuit and R is the resistance. It can also be calculated using the formula E = I*(r + R), where r is the internal resistance of the power source.
What is the difference between series and parallel circuits?
In a series circuit, all components are connected in a single loop, meaning that the current is the same at every point in the circuit. In a parallel circuit, components are connected in multiple branches, meaning that the current is divided between the branches. This affects how resistance and EMF are calculated in each type of circuit.
