Resistor equation problem
  1. Sep 26, 2015 #1
    The equivalent resistance of the series combination of two resistors is p.When
    they are joined in parallel, the equivalent resistance is q. If p = nq, find the
    minimum possible value of n.
    2. Relevant equations
    1/Rparallel = 1/R1+1/R2+...
    Rseries = R1+R2+...
    3. The attempt at a solution
    R1+R2=p
    R1 R2 / ( R1 + R2 ) = q
    Then, I substitute p as nq
    R1+R2=nq
    I divide the equation 1 and equation 2 and get
    ##n=\frac{(R_1+R_2)^{2}}{R_1R_2}##
    which I think that the minimum value is zero
    However, the textbook says that the answer is 4
    Please help
  3. Sep 27, 2015 #2
    ehild
    R1+R2=nq. Resistances are positive quantities. If n=0 R1+R2 =0. Is it possible???
  4. Sep 27, 2015 #3
    Hmm.. Yes, you're right.. It's impossible
    So, how come we get 4 ??
    I think of using derivative to get the minimum value..
    The y-axis is n
    But, I don't know what my x-axis is.
  5. Sep 27, 2015 #4
    ehild
  6. Sep 27, 2015 #5
    rude man
    hint: fix R2 = constant, then minimize n with respect to R1 & see what if anything comes out of it.
  7. Sep 27, 2015 #6
    n=\frac{R_1^2+2R_1R_2+R_2^2}{R_1R_2} = 2 + \frac{R_1^2}{R_1R_2} + \frac{R_2^2}{R_1R_2}
    The AM GM of function y= ##\frac{R_1^2}{R_1R_2} + \frac{R_2^2}{R_1R_2}## is
    \frac{R_1^2+R_2^2}{R_1R_2} \geq 2\sqrt{\frac{R_1^2 R_2^2}{R_1^2 R_2^2}}
    ## \frac{R_1^2+R_2^2}{R_1R_2} \geq 2 ## The minimum value of this function is 2
    So, the minimum value of n is 2+2 = 4...
    Thanks a lot for your help !
Have something to add?
Draft saved Draft deleted
Similar Discussions: Resistor equation problem
  1. Resistor problems (Replies: 1)
  2. Resistor problems (Replies: 1)
  3. Resistors problem (Replies: 27)
Loading...
