Resistor L pad
  • Thread starter Idea04
Idea04
194
I have a source of 800 Kilo Ohms and I want to power an LED with that source. Which I would presume the LED would have a resistance of 9.5 to 10 Ohms if I'm correct. When I connect the LED to the source the voltage drops from 12 volts DC to around 1 volts DC. If my thinking is correct the reason this is happening is because of the impedance mismatching in which a high impedance source is driving a low impedance load and the voltage drops to a much lower value.
To correct this I want to put a resistor L pad between the source and load to hopefully minimize the voltage drop. The value of resistor I calculated being would be 800 Kilo Ohms resistor in series with the source and a 10 ohms resistor in parallel with the load.
Is this correct? And if not where am I wrong.
Answers and Replies
sophiecentaur
6,071
You can't say that a diode has fixed "resistance" because it doesn't follow Ohm's Law. The voltage/current relationship is very non-linear. With an LED, you would normally assume that it has a more or less constant voltage across it and you would pass a current through it which would be defined, usually, by a supply voltage in series with a resistance.
Your "800kΩ" source needs to have an emf (voltage) specified before you can say what current will pass through the diode.
Tell us the specific context of this with a circuit diagram, if possible, and we can probably help you.
As it stands, your question can't be answered except to say that a 12V source with 800kΩ in series will only pass 12/800e3 Amps, or 15microamps. That will not light an LED!
vk6kro
40
This is how you normally set up a LED to work from a battery:
[PLAIN]http://dl.dropbox.com/u/4222062/LED%20circuit.PNG [Broken]
You can see that the value of R is not given, but you can calculate it.
It has 10 volts across it and it has 20 mA flowing in it.
So, its resistance must be 10 volts / 0.020 Amps or 500 ohms.
If you really have to light a LED from a 12 Volt source with 800 K series resistance, you can use a circuit like this:
[PLAIN]http://dl.dropbox.com/u/4222062/LED%20circuit%20with%20transistor.PNG [Broken]
By adding a high gain transistor and a power source for the LED, you can use the transistor to control the LED.
You might just get enough current to light a high efficiency LED.
There will be about 15 µA of base current in the transistor. If it had a gain of 300 the collector current would be 4.5 mA. This would be visible on some LEDs.
Jiggy-Ninja
309
Depending on what he measured it with, his meter might not have enough input resistance to accurately measure a voltage source with 800kΩ of Thevinin resistance.
Suggested for: Resistor L pad
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
31K
  • Last Post
  • Last Post
