Resistor puzzle
  • Thread starter sheldon
sheldon
152
If you have 12 resistors, each rated for 600ohms, how could you arrange them to make a total resistance of 500ohms?
Answers and Replies
FZ+
1,599
The joyous algebraic method. :smile:
Let 1/a + 1/b = 1/c
c = a * b / (a + b)
let a = 600 x and b = 600 y and c = 500
(We are setting up a parallel circuit, one with x resistors, and the other with y resistors in parallel)
we get then
(x * y * 360000)/(600(x+y)) = 500
Which simplifies to...
x * y / (x + y) = 5/6
Which we can turn into:
x = 5y/(6y - 5)
Now, set y = 1.
x = 5 / 1 = 5
So one easy possiblity is to have 5 resistors in series on one branch and 1 on the other.
Multiply by two if you need to use all 12 resistors.
sheldon
152
I see how you get 500 ohms with 6 resistors but don't understand how you got it with 12?
You could do it with only 5 resistors
3 600 Ohm resistors in parallel (200 Ohms)
In series with:
2 600 Ohm resistors in parallel (300 Ohms)
= 500 Ohms.
FZ+
1,599
Oops.
For 12 resistors, the solution is:
3 in parallel, 3 in parallel and 6 in parallel joined in series.
sheldon
152
Ok I heard if you made a cube, which has 12 sides and put a 600 ohm resistor on them it would equal 500 ohms.
Yeah but...
How many cubes have twelve sides?
[edit]
Cheese, ok I drew it out and get it now,haha.
I've forgotten what the question was as I edit this, but looking at my sketch I see that starting at one of the corners of such an array and assuming a current of '1', the flow would split in three equal 'parts' (each carrying 1/3). The three split again in two directions (each then carrying 1/6). Next the 1/6 branches would combine again into three (each now carrying 1/3), and these three combine again to bring us back to the original amount inserted at an opposite corner.
Does that make any sense?
Suggested for: Resistor puzzle
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
