Resistors and Voltage
  • Thread starter TyErd
Provided that the output voltage is 4V, which one or more resistors can be removed to get the same output voltage.
V=IR
Im not sure if any working out is necessary here or not
Answers and Replies
rl.bhat
4,433
From the given data, find the emf of the cell.
To get the same output, what to do with X and Z so that the current in Y is 2 mA ?
Think about it this way: If you combined X and Y in series, you'd have two parallel resistors. If you removed one of those parallel resistors(Z!), the voltage across and the current through the other parallel resistor does not change.
okay EMF I calculated to be 6V, and then I combined X and Y to make another 3000ohm resistor and because I want output to be 4V, then that would mean current has to change from 2mA to 1.33mA correct? which means i can remove Resistor Z. Is that right im not sure
Related Threads on Resistors and Voltage
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
