Resolving a vector
  • Thread starter sphyics
1. A particle is performing uniform circular motion
the necessary centripetal force is provided by T2 -mgcos(theta) ****** no problem :)
2 Now the problem
how to resolve vector W in this case.
i'm confused :( how to resolve the vector. (confused in picking the anlge between the vector and the component)
pls help me by providing some hints pls..
Answers and Replies
kuruman
Insights Author
3,837
Extend the line along W until it intersects the horizontal axis. You have just created a right triangle. One right side is W, one right side is the segment of the horizontal axis and the hypotenuse is T1. Can you find the component of W along T1?
my aim is to find a component of W which balances tension (T1) of the string and another component which tries to decrease the velocity of the object in circular motion in first quadrant.
kuruman
Insights Author
3,837
I understand your aim. As you know, to describe the components of a vector, you need two perpendicular axes. What do you think these axes should be in this case?
or
but in both cases the angle between the vector w and its x componet is not congurent to (theta) {i think so}
kuruman
Insights Author
3,837
... but in both cases the angle between the vector w and its x componet is not congurent to (theta) {i think so}
Your diagrams are fine, but you did not tell which way your axes point. In what direction is x?
kuruman
Insights Author
3,837
In that case, the weight has zero x-component and -mg for the y-component. What would happen if you chose the x-axis along T1 and the y axis perpendicular to it, up and to the left? Note that this is a very convenient coordinate system because the centripetal acceleration and tension are along x. Of course you will have to find the x and y components for the weight in the system of axes.
Related Threads on Resolving a vector
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
