Homework Help: Resolving components
  1. Mar 6, 2013 #1
    I know this is easy, but i cant seem to sort out how to structure it properly.
    This is the question:
    A man is pole vaulting. Also ignore air resistance.
    A man exerts a force of 810 N on a pole, at an angle of 80 degrees below the horizontal.
    If the man's weight is 600 N, what is the net force acting on the man as he pushes the pole away? Include the direction and the magnitude.
    2. Relevant equations
    3. The attempt at a solution
    Would the net force by 810 + 600? And isn't it meant to have a direction as well? Sorry, im a bit confused.
  3. Mar 7, 2013 #2
    ehild
    Add the forces as vectors.
    ehild
  4. Mar 7, 2013 #3
    Im struggling to deal with the weight component.
    Would you assume it has no horizontal component and only a verticle one?
  5. Mar 7, 2013 #4
    What I've tried:
    Solved the Force (F1) with the 810N into components:
    F1x = 810 sin 80 = 797.60
    F1y = 810 cos 80 = 140.66
    and the weight into components
    Wx = 0 (is this right? there's no horizontal component because it's pointing down?)
    Wy = 600N
    and then added them together
    = (797.69, 740.66)
    applied Pythagoras to get the total magnitude
    magnitude = sqrt( 797.69^2 + 740.66^2)
    = 1088.48N
    and then finding the direction
    theta = tan^-1 (y/x)
    theta = tan^-1 (740.66/797.69)
    theta = 42.88 degrees
    thus, the total force acting on the man is 1088.48N in the direction of 42.88 degrees below the horizontal
  6. Mar 7, 2013 #5
    What direction are your x- and y-axes pointing in?
    The problem says that the weight is 500N
  7. Mar 7, 2013 #6
    bugger. in my horrible handwriting, ive made a 0 a 6. and that's a typo. ill edit it now. meant to be 600
    and the usual x and y axis
  8. Mar 7, 2013 #7
    edited in the new corrections
  9. Mar 7, 2013 #8
    Be careful with the signs - the weight is in the negative y-direction.
    Also, I think the sin and cos for the components of F1 are the wrong way round?
    What angle is the force of the pole on the man making with the x-axis?
  10. Mar 7, 2013 #9
    ok, so the F2 should be (0, -600)?
    and i thought that sin was the opposite side of the triangle to the angle you are looking at. so the opposite side to the 80 degree angle
  11. Mar 7, 2013 #10
    Yes.
    F1 makes an angle of 80° with the positive x-axis.
    Is this the way you've got it?
  12. Mar 7, 2013 #11
    yeah, it makes an angle of 80 degrees BELOW the positive x axis
    and F2(0, -600) is right?
    thank you so much for your help mate.
  13. Mar 7, 2013 #12
    The force of the man on the pole is 80° below the x-axis.
    So, the force of the pole on the man is 80° above the x-axis.
    Yes
  14. Mar 7, 2013 #13
    Ohhh i see. So the force is acting basically 180 degrees to what i thought.
    It's the opposite reaction no?
    So how does this change my equations?
    (if i ever meet you in real life, you're getting a foot rub)
  15. Mar 7, 2013 #14
    Yes, this is the Newton3 reaction force - you want the force on the man.
    If you draw the free-body diagram for the man you'll see your equations are almost right, but the sine and cosine are the wrong way round.
  16. Mar 7, 2013 #15
    the sine and the cos are the wrong way
  17. Mar 7, 2013 #16
    thank you so much man. i appreciate it so much
Have something to add?
Draft saved Draft deleted
Loading...
