How Do Resonances Differ from Virtual States in Quantum Physics?
In summary, a resonance is a state with a pole in the S-matrix element in the complex energy plane, usually seen as a sharp peak in an s-channel scattering diagram. It has a finite lifetime and can be interpreted as a particle in some cases. On the other hand, virtual states have no fixed boundary and can be referred to differently in different fields. They are typically seen as internal lines in Feynman diagrams and cannot be easily interpreted as particles.
snorkack
2,190
477
What´s the difference between a resonance and a virtual state?
For comparison, a standard moderately lived state, hydrogen 2p state, has energy of 10,2 eV above ground, and width 4*10ˇ-7 eV.
An example of resonance is Delta - with mass 1232 MeV, it´s energy is about 290 MeV above ground (nucleon) and width around 110 MeV.
And then there are virtual states, like virtual paradeuteron. Paradeuteron is supposed to be a state unbound by around 60 keV, and is very important for proton-neutron scattering.
What is technical difference then comparing a resonance with a virtual state?
There is no fixed boundary, and different fields (particle physics, nuclear physics, ...) can use different names for the same things. In particle physics, the dividing line between "resonance" and "particle" is usually drawn somewhere at a width of something like 1/10 the particle mass. If the width is larger, you don't have a chance to get a reasonable mass peak.
Both, "virtual particles" and "resonances" can, strictly speaking, occur only as internal lines in Feynman diagrams and thus are (strictly speaking) not easily interpretable as particles.
A resonance occurs usually in an s-channel scattering diagram, and is defined by a pole in the complex energy plane of the corresponding S-matrix element. If such a pole is not too far from the real axis, you see a sharp peak. The full-width-half-maximum width then gives approximately the "lifetime" of the resonance (a better estimate is the energy derivative of the scattering phase shift of the scattering process in question). For narrow resonances one has an approximate "particle interpretation", because it lives long enough as an excitation of the quantum field. E.g., pions decay only through the electroweak interaction and are thus long lived on a typical time scale for reactions in the strong interaction.
Hadron resonances are usually not that stable, because they decay through the strong interaction. E.g., the ##\Delta(1232)## resonance in the elastic pion-nucleon scattering has a mass of about ##1232 \,\text{MeV}## and a width of about ##120 \, \text{MeV}##.
1. What is the difference between resonance and virtual state?
Resonance and virtual state are both concepts used to describe the behavior of particles in the quantum world. Resonance refers to a state where a particle is excited to a higher energy level, while virtual state refers to a temporary state that exists due to the uncertainty principle. Essentially, resonance is a real state that can be observed, while virtual state is a theoretical concept.
2. How are resonance and virtual state related?
Resonance and virtual state are related in that they both involve the behavior of particles in the quantum world. In some cases, particles in a virtual state can transition into a state of resonance, meaning they become excited to a higher energy level. However, this is not always the case and the two concepts are distinct from each other.
3. Can you give an example of resonance and virtual state?
An example of resonance is the Bohr model of the atom, where electrons can transition between energy levels by absorbing or emitting photons. An example of virtual state is the Casimir effect, where particles in a vacuum can briefly exist in a virtual state due to the uncertainty principle.
4. How do resonance and virtual state affect particle interactions?
Resonance and virtual state can both affect particle interactions in different ways. Resonance can lead to the emission or absorption of particles, while virtual state can affect the strength of interactions between particles. Both concepts are important in understanding the behavior of particles in the quantum world.
5. What are the practical applications of understanding resonance and virtual state?
Understanding resonance and virtual state is crucial for developing technologies such as lasers and transistors, as well as for research in fields such as quantum computing and particle physics. By understanding the behavior of particles in these states, scientists can make advancements in various industries and gain a deeper understanding of the fundamental principles of the universe.
  • Beyond the Standard Models
  • STEM Academic Advising
  • Science and Math Textbooks
17K
