1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Resonant Frequency
  1. Aug 26, 2014 #1
    1. Hollow tube chimes are made of metal and are open at each end. One chime is 0.54m long.
    -If the speed of sound is 346m/s, what is the frequency of sound produced by the third resonant length?
    -What would happen to the frequency of sound produced by the third resonant length if the chime were shorter?
    3. I'm having a hard time with this question, but here's my attempt:
    Info: 0.54m, Speed of sound=346m/s
    Half of one wavelength is the length of the chime.
    λ=0.54m*2
    λ=1.08m
    Find frequency:
    v=ƒ*λ
    346m/s=ƒ*1.08m
    ƒ=346/1.08
    ƒ=320Hz
    Find the third resonant length:
    L3=5λ/4
    L3=5(1.08)/4
    L3=1.35m
    Find frequency at this length:
    ƒ=v/λ
    ƒ=346m/s/1.35
    =256Hz
    3rd resonance frequency should be around 960Hz
  3. Aug 27, 2014 #2
    BvU
    L3 is still the length of the pipe, so ##\lambda## is a lot smaller than the 1.08 m you use...
    The 5/4 isn't correct either: both ends are open
  4. Aug 27, 2014 #3
    AlephZero
    From the information given, I suppose you are meant to solve the problem like the OP did.
    But in real life the frequency of a hollow tube chime depends on the vibration of the tube bending like a beam, not on the length of the air column inside.
  5. Aug 27, 2014 #4
    I've solved it myself. It's actually quite simple, I was using the wrong equation for resonant frequency.
    λ=0.54m*2
    λ=1.08m
    Use first resonant frequency equation:
    F1=v/λ
    F1=346/1.08
    =320Hz
    Now multiply the first resonant length frequency by 3 to achieve the third resonant length frequency.
    320*3=960Hz.
  6. Aug 27, 2014 #5
    BvU
    Well done.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Resonant Frequency
  1. Resonance frequency (Replies: 4)
  2. Resonance frequency (Replies: 0)
  3. Resonance Frequency (Replies: 17)
Loading...
