Homework Help: Response functions
  1. Sep 7, 2009 #1
    Consider you are conducting an experiment of using a photometer to measure the radiation from a blackbody source. Write down the expression for the received flux from the blackbody for two different cases:
    a) your photometer has a square-response function going from wavelengths $\lambda_1$ to $\lambda_2$ with an efficiency of X.
    b) your photometer has an efficiency characterised by the function f(\lambda).
    2. Relevant equations
    None
    3. The attempt at a solution
    a) X \cdot \int_{\lambda_1}^{\lambda_2} B(\lambda,T) \, \mathrm{d}\lambda
    where B(\lamba,T) is the Planck function
    b) \int_{0}^{\infty} B(\lambda,T) \cdot f(\lambda) \, \mathrm{d}\lambda
    Is this correct? I am confused as to whether I should be multiplying inside the integrand or doing some kind of convolution in Fourier space or something?
    Thanks,
    Natski
Draft saved Draft deleted
