Homework Help: Rewrite in index notation
  1. Sep 30, 2009 #1
    w=∇×u Is this correct? w_i=ε_ijk ∂/(∂x_j ) u_k
    w and u are the vectors
    C=(x∙y)z Is this correct? C_i= ∑_i〖(x_i y_j)∙z_i 〗
    C, x, y, z are vectors
    A^T∙A ∙x=A^T∙b Is this correct? A_ij^T∙A_ij∙x_j=A_ij^T∙b_i
    A is tensor and x and b are vectors
    A^T is A transpose
  3. Sep 30, 2009 #2
    HallsofIvy
    Assuming you are not using subscripts and superscripts to distinguish between a vector and its transpose, yes, that is correct.
  4. Sep 30, 2009 #3
    Hall is usually right on, though this one should be (assuming orthonormal coordinates)
    C=(x∙y)z C_j = z_i ∑_j (x_j y_j)
  5. Sep 30, 2009 #4
    I want to make sure the way I am writing this A^T dot A dot x = A^T dot b in index notation correctly.
    Would you mind to do that one time for me so that I can match up with my answer?
    My answer was
    A^T dot A dot x = A^T dot b >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    >>>>>>>>>>>>>>> A_ij^T dot A_ij dot x_j = A_ij^T dot b_i
    A_ij^T mean A_ij is a tensor with ij components and A^T mean the transpose of A
    x and b are both vector
    This problem was asking me to rewrite the A^T dot A dot x = A^T dot b in index notation. Thank you!
  6. Sep 30, 2009 #5
    Just a quick hint before I knock off. The transpose of a matrix interchanges rows with columns. (A_ij)^T = A_ji.
    To make the conversion to index notation it's convenient to think of the first index as indexing rows and the second as indexing columns:
    C dot D = ∑_j (C_ij D_jk)
  7. Sep 30, 2009 #6
    Is this correct? ∑_ j A_ji dot A_ij dot x_j = ∑_ i A_ij^T dot b_i ?
  8. Oct 1, 2009 #7
    The summation should occur between only two tensors. As you've written it, you are summing over all three on the left hand side.
    I should have noticed this earlier, but you should place the dot operator only between two vectors.
    U·V = UVT = ∑i Ui Vi
    Vector U is multiplied with the transpose of vector V.
    So we should write the expression AT·Ax as
    ATAxT, where A is a matrix, ATA is a matrix, and x is a row vector.
    ATA is equal to AijT multiplied by Aij, which means we are going to multiply the rows of the first matrix by the rows of the second
    ATA = ∑i Aij Aij
    For cut and paste.
    α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ ς σ τ υ φ χ ψ ω . . . . . Γ Δ Θ Λ Ξ Π Σ Φ Ψ Ω
    ∂ ∫ ∏ ∑ . . . . . ← → ↓ ↑ ↔ . . . . . ± − · × ÷ √ . . . . . ¼ ½ ¾ ⅛ ⅜ ⅝ ⅞
    ∞ ° ² ³ ⁿ Å . . . . . ~ ≈ ≠ ≡ ≤ ≥ « » . . . . . † ‼
