CCalc - Calculating Reynolds Number for an Impinging Jet
In summary, Reynolds Number is a dimensionless number used to predict the type of flow in a fluid system. It is calculated by multiplying the fluid's density by its velocity and diameter, then dividing by its viscosity. Reynolds Number is important in fluid mechanics as it helps determine the efficiency and performance of a system. It can be divided into three ranges: laminar flow, transitional flow, and turbulent flow. Reynolds Number can be affected by various factors, such as fluid velocity, viscosity, density, and diameter, as well as changes in fluid temperature and surface roughness.
mm391
66
I am trying to work out a reynolds number for an impinging jet using air. If I have:
μ=1.8*10-5 kg/ms
ρ=1.2 kg/m3
Velocity = 90m/s
Nozzle Diameter=15mm
is it Re = ρ u dh / μ
Which is (1.2 kg/m3*90m/s*0.015m)/1.8*10-5 kg/ms
Thanks
M
That depends entirely on the application. That would likely be the most commonly used formulation but there could be others.
If that's the data you're given then that's probably the formula you have to use. If you're unsure then check that your final answer is dimensionless i.e. has no units.
What is Reynolds Number?
Reynolds Number is a dimensionless number used to predict the type of flow in a fluid system. It is named after Osborne Reynolds, a British engineer who first described its significance.
How is Reynolds Number calculated?
Reynolds Number is calculated by multiplying the fluid's density by its velocity and diameter, then dividing by its viscosity. The formula is Re = (density * velocity * diameter) / viscosity.
What is the importance of Reynolds Number in fluid mechanics?
Reynolds Number is important because it helps determine whether a fluid flow is laminar or turbulent, which can greatly affect the efficiency and performance of a system. It also helps predict the occurrence of flow separation, pressure drops, and other phenomena.
What are the different ranges of Reynolds Number and their corresponding flow types?
Reynolds Number can be divided into three ranges: laminar flow (Re < 2300), transitional flow (2300 < Re < 4000), and turbulent flow (Re > 4000). Laminar flow is characterized by smooth, orderly movement of fluid particles, while turbulent flow is chaotic and unpredictable.
What factors can affect Reynolds Number?
Reynolds Number can be affected by various factors, including fluid velocity, viscosity, density, and diameter. Changes in these parameters can cause the flow regime to shift from laminar to turbulent or vice versa. Additionally, changes in fluid temperature and surface roughness can also affect Reynolds Number.
14K
  • Mechanical Engineering
  • Classical Physics
