Is the Landau pole in QED an artifact of perturbative methods?
  • A
  • Thread starter Demystifier
  • Tags
    Group
In summary, the concept of Renormalization Group (RG) can be viewed as a group or a semi-group, depending on the specific formulation used. For renormalizable theories, where the renormalized Hamiltonian has the same form as the original Hamiltonian, the RG transformation can be seen as invertible in the space of parameters, making it a true group. However, when considering the Wilson RG, which describes a parameterized family of effective QFTs, the transformation is not invertible and can be seen as a semi-group. The difference between these two views lies in the focus on the large momentum behavior in the Wilson RG and the low energy behavior in the Stückelberg RG. Overall, the concept of RG is a
Demystifier
Insights Author
6,649
TL;DR Summary
Is renormalization group a true group for renormalizable theories?
It is often said that the renormalization group (RG) is not a true group but only a semi-group, because the RG transformation is not invertible. But for renormalizable theories, the renormalized Hamiltonian has the same form as the original Hamiltonian, only with some different values of the finite number of parameters (coupling constants). Denoting the set of these "coupling constants" as ##g=(g_1,\ldots,g_n)##, for a renormalizable theory we have a set of coupled equations of the form
$$\frac{dg_i(t)}{dt}=\beta_i(g(t))$$
where ##t## is the scale parameter. Such equations can be solved uniquely in both forward and backward directions of ##t##, so in this sense the RG transformation is invertible. Does it mean that RG is a true group for renormalizable theories?
Likes thephystudent
Demystifier said:
I couldn't find it, what page?
Near the bottom of p42
Likes Demystifier
I see, thanks! The relevant quote is this:
"... the RG procedure is sometimes referred to as a semi-group. The term applies
to the action of RG on the space of configurations: each magnetization profile is mapped uniquely to one at larger scale, but the inverse process is non-unique as some short scale information is lost in the coarse graining. (There is in fact no problem with inverting the transformation in the space of the parameters of the Hamiltonian.)"
But in particle physics the RG is usually formulated without any coarse graining, using only the requirement that certain physical quantities do not depend on the scale ##\mu## appearing in dimensional regularization. It looks as if in such a formulation there is no reason to say that RG is only a semi-group.
Likes thephystudent and bhobba
I have just checked the book Pascual and Tarrach, QCD: Renormalization for the Practitioner, which indeed is a particle physics book based entirely on dimensional regularization. In Sec. IV The Renormalization Group, they state explicitly that a composition of renormalizations has the full group structure whenever the composition is defined, but note that composition is not defined for arbitrary two elements of the group, in which case it has only a grupoid structure. (A grupoid is even more primitive than a semi-group in the sense that the product in a grupoid does not need to be associative.)
Likes vanhees71 and bhobba
There are two different concepts of RG, The earlier by Stückelberg is a group, the later by Wilson is only a semigroup.
Likes Auto-Didact, vanhees71 and Demystifier
Stückelberg's RG describes a change in parameterization of a single QFT, which makes it a group. On the other hand, Wilson's RG describes a parameterized family of effective QFTs involving more and more coarsening it in the process, whence it is not invertible.
Likes Auto-Didact and vanhees71
But when the theory is renormalizable, the members of a Wilson family differ only by the values of the parameters (coupling constants), which makes it effectively the same as the Stückelberg's change of parameterization. Sure, the Wilson coarsening is not invertible, but its effect - the change of effective parameters - is invertible.
To make an analogy, this is somewhat like computation of an invertible function on a physical computer. The work of a physical computer is not invertible (it produces heat), but the result of computation is invertible.
I think it would not be wrong to say that Wilson's RG describes what is really going on physically, while Stückelberg's RG is a convenient recipe to get the final results of practical interest. Roughly speaking, something like QM with and without "hidden variables". The final measurable results are the same, but the philosophies are very different.
No. The large momentum behavior is altered!
But from the Wilson point of view that's irrelevant, because it's the small momentum behavior (small compared to the Wilson cutoff in the momentum space) that one wants to describe with an effective theory.
It is irrelevant for the low energy behavior. But it makes mathematically the essential difference between a group and a semigroup. For a group one needs invertible mappings, but from a low energy effective theory one cannot recover the higher energy effective theory.
It depends on what one means by "theory". If the theory is just the Hamiltonian (or Lagrangian), and not one particular solution associated with that Hamiltonian, then one can recover it for renormalizable theories. That's indeed what Kardar said (post #5) in different words, by saying that RG is not invertible in the space of configurations, but is invertible in the space of parameters.
No. The Wilson RG is a map between effective theories, and these are all nonrenormalizable.
Effective theories are renormalizable order by order in the momentum expansion. Some are non-renormalizable in the sense of "Dyson-renormalizable", which latter means that the theory is renormalizable order by order in the expansion of powers of ##\hbar## (or order by order in powers of the coupling constant, where however one has to be careful with gauge invariance).
I n this sense all QFTs are renormalizable, and the term used in this sense has lost its discriminating meaning.
Well, the distinguishing property is that Dyson-renormalizable theories have a finite number of coupling constants, while the effective theories have infinitely many since in any higher loop (##\hbar##) order (i.e., also higher powers of momentum) you need new counterterms.
No, effective theories can also be renormalizable. For example, the Standard Model is also likely to be an effective theory (emerging perhaps from string theory, or something else).
The Wilson RG is a map between effective theories, and these are almost all nonrenormalizable.
The few exceptions don't change the argument.
The standard model may be an approximation to an underlying theory but it need not be regarded as an effective theory. Even when one does, one cannot recover from it the underlying true theory, since it lacks the more fundamental degrees of freedom. This gives an explicit counterexample to your claim that
I agree and I never claimed the opposite. Just because RG gives well defined non-infinite results at small distances doesn't mean that it is right at small distances. And the same is true for large distances too.
Likes vanhees71
The few exceptions don't change the argument.The standard model may be an approximation to an underlying theory but it need not be regarded as an effective theory. Even when one does, one cannot recover from it the underlying true theory, since it lacks the more fundamental degrees of freedom. This gives an explicit counterexample to your claim that
Do you think the standard model really has no problems with Landau poles? Isn't at least QED as part of the SM likely to have a Landau pole? If it has one, I think it's validity is constrained to energy-momentum scales not too close to the Landau pole, or is there a way to avoid the trouble with the Landau pole somehow and make it a theory valid on all energy scales?
Indeed, and that's good. After all the experimentalists should also have some work to do in ruling out theorists' phantasies ;-))).
Likes Demystifier
The Gross-Neveu model in 1+1D has a Landau pole but has been rigorously constructed.
QCD, which is asymptotically free, has, due to infrared effects, a Landau pole (and unlike QED) at physically realizable energies. Nevertheless it seems to be a sound theory.
Therefore, in contrast to the original beliefs, Landau poles say nothing about the existence or nonexistence of a theory. They are just an artifact of incorrectly summing up pieces of the perturbative expansion. We discussed this here in another thread.
Likes Demystifier
What do you mean by "rigorously constructed"? Is it well-defined in the mathematical sense, but has a Landau pole? But then doesn't it break down at this pole as a physical theory (i.e., one that can in principle be interpreted as describing observable entities (which you may call "particles"?) at any energy scale)?
The 2nd paragraph seems to contradict the first. You say the GN model in 1+1 dimensions has been rigorously constructed and has a Landau pole. On the other hand you say, the Landau pole is an artifact of incorrectly summing up pieces of the pert. series. Shouldn't this imply that a completely constructed 1+1-dim. GN model shouldn't have a Landau pole since there you don't use a pert. expansion to begin with?
The other thread makes more sense to me, but it also tells you that perturbative QED doesn't make sense close to the Landau pole. Since QED is well-defined in the low-energy region, it's thus an effective theory with the upper energy scale defined by the Landau pole. I think it's pretty clear that the problem of a Landau pole doesn't depend on the specific regularization you use to define the renormalized theory. I think it's also there in BPHZ, where you just substract integrands without introducing an explicit regularization at all.
Concerning pQCD it's pretty similar: The perturbative expansion makes sense at large scales. If there's a Landau pole at lower scales, you cannot go close to it either, but that makes perfect sense, since in the low-energy limit your perturbative expansion becomes ill-defined. FAPP you simply use the wrong effective degrees of freedom. The low-energy effective theory of QCD is some hadronic field theory, using some symmetry principles like approximate chiral symmetry in the light-quark sector, heavy-quark effective theory in the heavy-quark sector etc.
A Landau pole is a phenomenon related to the perturbative expansion. To say that GN has a Landau pole means that if you work out the renormalized perturbative expansion based on its Lagrangian and resum it in the same way as it is done in QED you get a pole at some ultrahigh energy.
Nevertheless, a nonperturbative construction of GN exists in the sense that the Wightman axioms hold. Hence a sensible physical interpretation exists in terms of causal fields and asymptotic particle states via Haag-Ruelle theory.
The construction shows no trace of anything anomalous. Thus the Landau pole is an artifact of the method of obtaining it.
Standard perturbative QED defined via a cutoff as renormalization parameter makes no sense there, since QED is obtained only in the limit where the cutoff is removed.
Perturbative QED defined via causal perturbation theory makes sense at all energies, since the renormalization parameter can be chosen everywhere except at the pole itself, and all renormalization parameters define QED, just in different parameterizations.
Likes mattt and vanhees71
1. What is the Landau pole in QED?
The Landau pole in QED (Quantum Electrodynamics) is a hypothetical singularity in the theory that arises when the coupling constant, which measures the strength of the electromagnetic interaction, becomes infinitely large. This would lead to inconsistencies and breakdown of the theory.
2. Is the Landau pole a real physical phenomenon?
No, the Landau pole is not a real physical phenomenon. It is an artifact of perturbative methods used in theoretical calculations. It arises due to the limitations of perturbation theory and does not have any physical significance.
3. How does the Landau pole affect the predictions of QED?
The Landau pole does not have any significant impact on the predictions of QED. It only appears in higher order calculations and can be removed by using more sophisticated non-perturbative methods.
4. Can the Landau pole be avoided in QED calculations?
Yes, the Landau pole can be avoided by using non-perturbative methods such as lattice QED or Dyson-Schwinger equations. These methods take into account the non-perturbative effects and do not lead to the appearance of the Landau pole.
5. How does the existence of the Landau pole affect our understanding of QED?
The existence of the Landau pole does not affect our understanding of QED as a well-established and successful theory. It is simply a mathematical artifact that does not have any physical significance. The use of non-perturbative methods allows us to make more accurate predictions and avoid the Landau pole.
  • Quantum Physics
  • Atomic and Condensed Matter
9K
  • High Energy, Nuclear, Particle Physics
  • Quantum Interpretations and Foundations
