Calculating Distance Between Two Places Along 66° Latitude (Rhumb Line)
In summary, the distance between two places, A (66°N and 20°W) and B (66°N and 90°A), along the 66° latitude (rhumb line) is 4974 km. This can be calculated by finding the radius of the 66° latitude circle (6370*cos(66)), determining the angle between the two places (110°), and using the formula (angle/360) * circumference to find the distance. The final answer is 4974 km.
prinsinn
Two places, A (66°N and 20°W) and B (66°N and 90°A). Find the distance between them if you go along the 66° latitude (rhumb line).
The answer is 4972 km but I don´t know how to calculate this. Please help me.
A constant latitude curve is just a circle. Can you find it's radius? At 0 latitude it's just the radius of the earth. As you approach the poles it goes to zero. Think of a trig function to apply.
The radius of the Earth is 6370 km.
I know how to calculate the great circle (the shortest distance). This is how I did that.
a = 90-66 = 24
b = 90-66 = 24
C = 20+90 = 110
I put these numbers into the formula
cos(c) = cos(a)cos(b) + sin(a)sin(b)cos(C)
which gives me c = 0.7779 = 0.67935 rad
and 0.67935 * 6360(radius of earth) = 4327 km.
This is how to find the great circle but I have tried so hard to find the distance if I go along the 66° latitute but I don´t get the right answer. Please show me how to do that.
Compute the radius of the circle (not a great circle) following 66 degrees latitude. Take a point on that circle, connect it perpendicularly to the Earth's axis and then connect that to the Earth's center. You've just drawn a right triangle. The hypotenuse is the radius of the Earth and the first leg is the radius of the latitude circle. Find an angle in that triangle and use trig to find the radius of the latitude circle.
Ahh, I'm getting closer,
I think the radius of the 66° latitute is (6370/90)*66 = 4671.
I don't know what to do next. I think I have to find the angle between places A and B and divide it by 360 and multiply by the new radius, 4671.
I don't unerstand how to take a point on the circle, connect it perpendicularly to the Earth's axis and then connect that to the Earth's center.
No. The radius of the 66 degree latitude circle 6370*cos(66 degrees). It's really hard to explain how to draw the triangle in words and I see I'm failing so take my word for it and ask someone to draw the picture. Yes, then you find the angle difference, divide by 360 and multiply by r. But don't forget to multiply by 2*pi as well. The circumference of a circle is 2*pi*r.
Thank you so much, I did it right, you are a genius.
The radius of the 66° latitute is 6370*cos(66) = 2590.9 km
The circumference of 66° latitute is 2590.9*pi*2=16279 km
the angle between places A and B is 110°
so the answer is
(110/360) * 16279 = 4974 km
What is a rhumb line?
A rhumb line, also known as a loxodrome, is a line on the surface of a sphere that crosses all meridians of longitude at the same angle. In other words, it is a straight line on a curved surface.
How do you calculate the distance between two places along a rhumb line?
To calculate the distance between two places along a rhumb line, you can use the formula:
Distance = (latitude difference) x (earth's radius) x (cosine of the latitude)
What is the significance of 66° latitude in calculating distance along a rhumb line?
66° latitude is significant because it is the latitude where one degree of longitude is equal to one nautical mile. This makes it easier to calculate distances between two points using the formula mentioned above.
How accurate is calculating distance along a rhumb line?
Calculating distance along a rhumb line is not as accurate as using the Great Circle Distance formula, which takes into account the curvature of the earth. However, for shorter distances, the difference in accuracy is minimal.
Can the distance along a rhumb line be affected by the curvature of the earth?
Yes, the distance along a rhumb line can be slightly affected by the curvature of the earth, especially for longer distances. However, for shorter distances, the difference in distance is negligible.
