Ricci Tensor in Vacuum Inside Earth - Ideas Appreciated
In summary: The centrifugal term is also zero, because it is the product of the tangential and radial velocities, and the radial velocity is always zero in a vacuum.In summary, Raychauhurdi's equation states that the volume of a sphere of test particles decreases with time as the number of particles in the sphere decreases. This is due to the fact that the shear term (which is caused by the gravitational forces) becomes increasingly larger as the number of particles decreases, while the tidal and centrifugal terms remain zero.
AlanE
Imagine a hole drilled through the Earth from which all air has been removed thus creating a vacuum. Let a cluster of test particles in the shape of a sphere be dropped into this hole. The volume of the balls should start to decrease. However, in his article "The Meaning of Einstein's Equation" page 18, John Baez and Emory Bunn indicate that the rate of decrease of the volume, per volume, should equal the t-t component of the Ricci tensor. But how can this be if the Ricci tensor is zero in a vacuum? Any ideas would be appreciated.
What makes you think the volume should decrease? After a little thought, I agree that the volume will decrease, by analogy with the case I mention below. Basically a disk of test particles at the same height will reach the center of the Earth at the same time, which winds up implying the volume at the center of the Earth is zero.
I've never thought much about a ball of test particles being dropped into the center of the Earth, but I have thought more about a ball of test particle orbiting the Earth in a non-rotating spaceship. I think the conclusions are similar.
What happens is that V(t) does decrease with time, but if you look at Einstein's equation, it only says that ##\ddot{V}= 0## at t=0, when all the particles in the ball are initially at rest relative to each other. So if we plot V as a function of t, initially V does not change with time, but this is only true at t=0, it is not necessarily true that ##\ddot{V}= 0## at any other time. There is no requirement that V be a constant of motion. The only requirement is that at t=0, the second time derivative of the volume is zero.
Thanks for the reminder that merely having the second derivative equal to 0 doesn't imply that the volume won't decrease. I guess the equation for the change of volume could be something hypothetically like V(t) = V(1-kt3). or V(t) = V(1-kt**4) etc. I need to research this myself. Maybe someone knows the required equation even if only for Newtonian mechanics. :smile:
I believe the evolution of the volume in the general case would be given by Raychauhurdi's equation, https://en.wikipedia.org/wiki/Raychaudhuri_equation. But the goal is to make things as simple as possible, which Baez does by choosing initial conditions appropriately - those initial conditions being that the ball of test particles start out with all the particles relatively at rest. Then a lot of complexities disappear, and the underlying simplicity emerges.
Not quite. A disk is not a ball, and the version of Einstein equation under discussion only applies to a ball. A ball of test particles dropped from initial rest such that its center is at a given height will not all reach the center of the Earth at the same time (although the portion of the ball consisting of a disk transverse to the direction of fall will); the ball squeezes in the transverse direction but stretches in the radial direction.
Strictly speaking, this won't be true if any of the test particles in the ball meet at the center of the Earth, because Raychaudhuri's equation only applies to a congruence of non-intersecting worldlines. However, we can use it up until that point.
Looking at the RHS of the equation, there is only one possible nonzero term: the shear term ##- 2 \sigma^2##. The tidal tensor term is zero in vacuum (because it is the trace of the tidal tensor, which as noted is equal to ##R_{mn} X^m X^n##, and ##R_{mn} = 0## in vacuum). So the key thing to compute is the shear scalar of the congruence in question. It starts out being zero (because, roughly speaking, the shear scalar is a sort of average shear in all directions, and the positive shear in the radial direction is exactly canceled by the negative shear in the transverse direction). However, I'm not sure whether it continues being zero once the fall is in progress or not.
The later point is the one I was trying to make - if the disk, which is a sub-manifold of the ball, deforms to a point, we expect the volume of the deformed ball to wind up to be zero.
But this isn't inconsistent with Einstein's equation, for reasons that have already been discussed and which the OP seems happy with.
1. What is the Ricci Tensor in Vacuum Inside Earth?
The Ricci tensor in vacuum inside Earth is a mathematical term that describes the curvature of spacetime inside the Earth in the absence of matter or energy. It is part of the larger mathematical framework known as Einstein's field equations, which describe the relationship between matter and spacetime in the theory of general relativity.
2. How is the Ricci Tensor in Vacuum Inside Earth calculated?
The Ricci tensor in vacuum inside Earth is calculated using the Einstein field equations, which involve complex mathematical equations and derivatives. These equations take into account the mass and energy distribution inside the Earth and use them to calculate the curvature of spacetime.
3. What does the Ricci Tensor in Vacuum Inside Earth tell us about the Earth's interior?
The Ricci tensor in vacuum inside Earth provides valuable information about the structure and dynamics of the Earth's interior. It helps us understand the distribution of mass and energy inside the Earth, which can have significant implications for geological processes such as plate tectonics and volcanic activity.
4. Can the Ricci Tensor in Vacuum Inside Earth change over time?
Yes, the Ricci tensor in vacuum inside Earth is not a constant value and can change over time. As the distribution of mass and energy inside the Earth changes, the curvature of spacetime also changes, resulting in a different value for the Ricci tensor. This is why scientists continue to study and refine our understanding of the Earth's interior.
5. How does the Ricci Tensor in Vacuum Inside Earth relate to the concept of gravity?
The Ricci tensor in vacuum inside Earth is closely related to the concept of gravity. In the theory of general relativity, gravity is described as the curvature of spacetime caused by the presence of matter and energy. The Ricci tensor is a mathematical representation of this curvature, and it helps us understand and predict the effects of gravity on objects inside the Earth.
  • Classical Physics
14K
