Homework Help: Ricky Bobby and his pistol
  1. Mar 25, 2009 #1
    Ricky Plaxico Bobby grabs his .22 pistol and fires a 5.00g lead bullet into a block of wood. The muzzle Velocity 301 m/s. Assume that 50 % of the bullet turns to heat
    A.What is the temperature rise of the bullet?
    B. Will the bullet become hot enough to melt?
    C.If so, what percent of the bullet melts?
    2. Relevant equations
    L=alphaL(subzero)T
    3. The attempt at a solution
    I converted the equation to get the temperature
    L/alphaL(subzero)=T??? i get a weird answer can i get some help? please
  3. Mar 25, 2009 #2
    mgb_phys
    First work out the kinetic energy of the bullet
    then you need the specific heat capacity of lead to work out what temperature rise this energy corresponds to.
    And finally the melting point of lead.
    (Be careful of units, the bullet is given in grams )
  4. Mar 25, 2009 #3
    i found the the kinetic energy its 752.5 and the melting point of the lead is 327 celcius and the specific heat is 130 kg c..... i dont know how the kinetic energy plugs into this equation????? im using Q=mcT and to find Q i used this equation Q=mL, and then i pluged it in to this one but i know its wrong because the answer i got was cold and its suppose to be hot????
    (.005kg)(25kg= the heat fusion)=Q
    .125kg
    .125kg=(.005)(130)T
    T=.1923076923 C?????????????
  5. Mar 26, 2009 #4
    mgb_phys
    All the kinetic energy becomes heat.
    So Q = 1/2 m v2 and Q = m c T
    Where T is the change in temperature - you just need to find if the temperature change is enough to reach lead's melting point
