Challenge Riddles and Puzzles: Extend the following to a valid equation
  • Thread starter fresh_42
  • Featured
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
Am I to understand it does NOT spread to the smaller columns ? Please clarify this spreading (e.g. after D1 it can spread to D2 and to E1 -- not to C1 ?)
I don't know what you are quoting here, I said
the fire spreads to all horizontally or vertically neighboured hectares (no diagonals).
So ##D1\to C1, D2, E1## or ##F3 \to F2,F4,G3,E3##.
33,057
8,816
Improved fire fighting plan:
Make two "stairs". Save D2, E2, C3, F3, B4, G4, A5, H5 in that order. The fire needs two cycles to danger the next step in the stair, that means you can fight on both sides at the same time. A total of 20 fields will burn down.
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
122. You want to put groceries into the drawer. Between three round glasses of peanut butter is still some room left for another small bottle of olives. If the radius of the peanut butter glasses is ##R## and the radius of the glass of olives is ##r##, how big may be the ratio ##r/R## at most, such that the olives fit in?
D122
Constructing an equilateral triangle by connecting the centers of the peanut butter jars, we need to find the distance between the center of the triangle and one of the corners. This will be equal to R+r.
Thus using basic trig, we get that r = R(2/√3 -1). Thus r/R = (2/√3 -1)
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
123. Show that there are infinitely many ##11-##tuples of consecutive natural numbers such that none of them is prime.
D122
33,057
8,816
Consider x to x+10 where x=2310n+2 for a positive integer n (2310 = 2*3*5*7*11).
x, x+2, ..., x+10 are even, x+1 is divisible by 3, x+3 is divisible by 5, x+5 is divisible by 7, x+7 is divisible by 3, x+9 is divisible by 11. This gives an 11-tupel without primes for every positive n.
Alternative proof: If there would be only a finite set then the asymptotic prime density would have to be at least 1/11, in contradiction to that density going to zero.
Both proofs can be extended to arbitrary length of the tuples.
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
124. Two fair dice are rolled each round; the result of a throw is the product of the thrown numbers. A game goes over 5 rounds.
Alice throws 5 more points in the second round than in the first round, 6 less in the third round than in the second, 11 more in the fourth round than in the third, and 8 less in the fifth round than in the fourth.
How many points did she score in each of the 5 rounds?
D123
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
125. Find an integer which can be written as a sum of squares in three different ways.
D124
983
173
Doing #124
The first step is to collect the numbers. The problem statement is R2 = R1+5, R3 = R2-6, R4 = R3+11, R5 = R4-8.
We must now find dice-roll values that satisfy all these equations. The complete list of possible dice-roll values is (1, 2, 3, 4, 5, 6, 8, 9, 10, 12, 15, 16, 18, 20, 24, 25, 30, 36).
The possible values of (R1,R2) are ((1,6), (3,8), (4,9), (5,10), (10,15), (15,20), (20,25), (25,30)).
The possible values of (R1,R2,R3) are ((3,8,2), (4,9,3), (5,10,4), (10,15,9), (25,30,24)).
The possible values of (R1,R2,R3,R4) are ((5,10,4,15), (10,15,9,20))
The possible values of (R1,R2,R3,R4,R5) are only one: (10,15,9,20,12). That is the solution.
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
126. One of us has the least odd value under Euler's ##\varphi## function different from ##1##, and one of us is the least that doesn't occur in its range. The third of us tells how many colors are sufficient to color a map on a ring. Me? This is the product of them.
D124
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
127. Someone replaced the round shooting targets at the local gun club by equilateral triangles with a side length of 10 inches. Show that among five hits will always be two closer to each other than five inches.
D125
BvU
12,109
2,673
129 Make a drawing !
Worst case for 1, 2, 3 is in the corners. dashed radii are < 5" (by at least half a bullethole size) So equilateral triangle ABC has sides < 5" and you can't find two points in there that are > 5"apart
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
128. The riches of the country are redistributed after the revolution. Nine subordinates and the former king - a total of ten people - can distribute 10 thalers per month. So every person gets a gold thaler paid out every month - even the king.
The distribution key may be changed if there is a majority for it. A subordinate agrees to a change, provided this increases his own monthly salary. He votes against it when his wages fall. If his monthly salary does not change, he abstains. The king is not allowed to vote, but he is the only one who can suggest how to change the distribution.
What is the maximum monthly paycheck the king can secure##^*)##?
Additional question: The people consists of a total of 1000 people including the king. Each month, 1000 thalers are paid, at the beginning exactly one to each person. Which maximum sum is achievable##^*)## for the king now?
##^*)## This means in the long run.
D125
jbriggs444
7,512
2,564
7 and 997
Every successful change of distribution which begins with at least two subordinates having a non-zero distribution must also end with at least two subordinates having a non-zero distribution. If the result were to have only one subordinate with a non-zero distribution then there could have been at most one vote "for" and there would also have been at least one vote "against".
Consider a final redistribution that gives the king his maximum share. There must have been at least two subordinates receiving non-zero distributions. If both are victimized then three subordinates must vote in favor of the measure -- three thalers which the King cannot receive. If only one is victimized then at least two other subordinates must vote in favor of the measure. Again there are at least three thalers which the King cannot receive.
So we have an upper bound of n-3 = 7 thalers to the King.
What remains is to determine whether this upper bound is attainable. The following scheme will serve.
The first vote hands the King's thaler to subordinate number 1 and subordinate n's thaler to subordinate number 2.
After this, it is straightforward to take any subordinate with two or more thalers and redistribute them to two other subordinates, thus finally concentrating the wealth on at most two subordinates. Let n be the total distribution. Then these subordinates have k and n-k thalers respectively. Assume n is large enough that both n and n-k are greater than or equal to two (easily achievable for n=10 or n=1000).
The final moves go like:
Code:
K  S1 S2 S3 S4
0   k n-k 0 0
k-2 0 n-k 1 1
n-4 0 0   2 2
n-4 1 0   0 3
n-3 2 1   0 0
8,816
126. One of us has an odd value under Euler's ##\varphi## function, and one of us doesn't occur in its range. The third of us tells how many colors are sufficient to color a map on a ring. Me? This is the product of them.
D124
I'm confused by that one. ##\varphi(x)## is odd for x=1 and x=2 only, giving us two choices for the first number. No odd value apart from 1 occurs in its range (and various even numbers don't occur either), giving an infinite set of choices. The torus needs 7 colors.
That's a lot of options for the product.
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
Yeah, I should have added smallest number which doesn't occur in the range, and excluded ##1##. As ##1## wouldn't contribute to the product, I thought I could leave it.
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
129. A bag contains ##111## marbles in the colors red, green, blue, and yellow. If we take out ##100## marbles, we will have at least one marble of each color in our hand.
How many marbles do we have to take out at least, such that we will safely hold at least one marble of three colors in our hands?
D126
BvU
12,109
2,673
129
Each colour has at least 12 marbles in the bag. We can miss one colour and 11 from a second colour and still get three colours if we grab 88 marbles...
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
130. All, but less than 100 party guests, are distributed into teams of equal prime size for a game. Someone observed that the number of teams, except his, is also divisible by that prime. How many persons attended the party, if we assume that the observation is independent of the prime chosen?
D126
33,057
8,816
Let the team size be p. There are k groups. N=kp<100. We know that k-1 is divisible by p, let's write this as k-1=cp. Then N=(cp+1)p. As 100>N>p2 the only possible primes are 2, 3, 5 and 7.
For p=7 the only option is c=1, we have 8 teams of 7 members each, 56 members.
For p=5 we have the options c=1,2,3, leading to 6,11,16 teams of 5 members each, 30, 55, 80 members.
For p=3 we get 4, 7, 10, ..., 31 teams of 3 members, 12, 21, 30, ..., 93 members.
For p=2 we get 3,5,...,49 pairs, 6,10,...,30,...,98 members.
There is no prime power, therefore all party sizes have a choice how to split them into prime groups. While 66 appears in both p=2 and p=3 you could split 66 people into 6 groups of 11 members.
To split 30 in teams with a prime number of members we can only make teams of 2, 3 and 5, in all cases someone can make the described observation. That must be the solution.
fresh_42
Mentor
Insights Author
2018 Award
11,157
7,663
Yes, and the next Giuga number is 858.
Want to reply to this thread?
"Riddles and Puzzles: Extend the following to a valid equation" You must log in or register to reply here.
Related Threads for: Riddles and Puzzles: Extend the following to a valid equation
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
